R56 Half CEL light Still on please help
Old Sep 24, 2014 | 10:30 PM
JaysCoop07's Avatar
JaysCoop07
Half check engine light came on. Checked code P0303 (misfire cylinder 3) hoping/thinking spark plugs. Plugs look a little warn, so I changed all 4 (NGK iridium). Erased code with reader, started it up, cluster is still showing half CEL. Checked reader throwing no codes. Drove it around for 30 minutes checked OBD reader still no codes but light is still on.... My questions and concerns are
Do I have to reset the CEL light on cluster/dash manually? (I thought reader does that when you erase the code)
Any other problems with P0303 I should be concerned with?
Maybe the problem isn't fixed. How long will it take to throw a new code?
Please help..
Any information from Cel light to p0303 misfire is welcome! Knowledge is power!!
Old Sep 25, 2014 | 12:14 AM
Systemlord's Avatar
Systemlord
Please help..
You have left out the most important info, Non-S, Mini Cooper S and year?
Old Sep 25, 2014 | 12:32 AM
JaysCoop07's Avatar
JaysCoop07
Sorry about that,
2007 Mini Cooper S (r56)
Old Sep 25, 2014 | 02:37 AM
Systemlord's Avatar
Systemlord
Sorry about that,
Now for the mileage, you should know our N14 engines burn quite a bit of oil, 1.5 quarts per 1500 miles. I don't know your mileage but my engine began misfiring randomly with no CEL at all at 50,000 miles do to carbon buildup on the intake valves. Get into the habit of having your valves walnut blasted every 30-50,000 miles, this could be the reason why your getting a CEL. Other than the misfire code how is your engine behaving?
Old Sep 25, 2014 | 05:30 AM
jcauseyfd's Avatar
jcauseyfd
Are you talking about the half engine symbol that shows up in the tach display? If so, that is the reduced power symbol, not CEL. If that is what it is, you won't get codes via the OBD. You can drill down to get some codes, but usually they aren't very helpful unless you have access to MINI software to read all the codes and pull other info.
Old Sep 25, 2014 | 10:20 AM
Slave to Felines's Avatar
Slave to Felines
There is a code, but your reader can't see it. You'll need to get to a dealer, or to a good independent mechanic who has one of the MINI-specific (or BMW-specific) readers.
Old Sep 25, 2014 | 11:01 AM
JaysCoop07's Avatar
JaysCoop07
Hey everyone thank you for all your replies.
I Drove it to work (50mil) this morning and by the time i got to work the indication was gone...
Stopped and started it up again 2-3 times to make sure it was gone. The indication did not pop back up. Checked BC options engine check said "OK"
Hopefully it was just a matter of driving it around for the computer to reset/acknowledge the status..... i dont know
i'll drive it home and see if the light comes back on later but i will double check with a dealer aswell.
Thanks everyone!
Old Sep 25, 2014 | 11:52 AM
Systemlord's Avatar
Systemlord
Keep us posted if anything else pops up. Mileage?
Old Sep 25, 2014 | 11:58 AM
JaysCoop07's Avatar
JaysCoop07
Thanks i will.
Mileage : 99,875 almost to the 100,000 mile mark fingers crossed!
Old Sep 25, 2014 | 12:00 PM
Systemlord's Avatar
Systemlord
Thanks i will.
Have you ever had your intake valves walnut blasted? If not you're sure overdo, it's a common issue with N14's .
Old Sep 25, 2014 | 12:35 PM
ra2fanatic's Avatar
ra2fanatic
Check coil packs as well.
Teh
Jun 13, 2018 02:59 PM
blackie
Jan 18, 2017 09:56 PM
FLYM1N1
Mar 7, 2016 05:41 PM
David.R53
Sep 1, 2015 06:49 PM
Overpolished
Detailing 101
15
Aug 21, 2015 07:19 PM
