Reset Windows with NCS Expert ?
Old Sep 23, 2014 | 03:59 AM
wawefr's Avatar
wawefr
hello
The windows still have a problem even after raising a "manual" reset
after reading the forum the solution is to do a reset at the dealership
Before doing so I was wondering if this was possible via NCS Expert? and if so how?
In advance thank 's
Fred
Old Sep 27, 2014 | 04:48 AM
mrbean's Avatar
mrbean
NCS expert is used for coding modules (i.e. enabling/disabling functions). It's not used for performing "resets."
What specific problems are you having with the windows?
Old Sep 29, 2014 | 12:31 AM
wawefr's Avatar
wawefr
bonjour
merci pour ton aide
1) quand je remonte les vitres elle descendent de 5 cm une fois arrivées en haut.
2) quand on ouvre la porte la vitre devrait descendre un peu pour se décoller et elle ne bouge pas !!
il me semble que le paramétrage a disparu
encore merci
fred
Old Sep 29, 2014 | 12:32 AM
wawefr's Avatar
wawefr
hello =>>> excuse me i answer in french ...
thank you for your help
1) when I go back windows it get 5 cm once they reach the top.
2) When you open the door the glass should come down a bit to take off and it does not move !!
I think the setting is gone
again thank you
Old Sep 30, 2014 | 02:56 PM
mrbean's Avatar
mrbean
If you have NCS expert, then you may also have INPA.
INPA can perform the same reset as the Mini dealership.
If you cannot use INPA, the go to the dealership for a reset.
nomar116
Jun 1, 2018 07:55 AM
n0mis
MINI5280
11
Mar 9, 2016 05:04 PM
simo711
Sep 29, 2015 11:53 AM
nomar116
Electrical
Sep 20, 2015 10:26 AM
Sep 14, 2015 12:48 PM
