When A/C is on I get this rattle sound. Any help?
Old Sep 20, 2014 | 09:34 AM
Fatandre's Avatar
Fatandre
When A/C is on I get this rattle sound. When a drive the car it is all good.
Then when I stop at a light and the car idles I get this rattle or like the engine starts to shake, but more of a rattle.
When I turn of the A/C it stops like 1 min later. All is good without the A/C on
My steering pump fan might be also shot, could that effect that?
My car is a 2005 MCS
Old Sep 20, 2014 | 01:24 PM
ZippyNH's Avatar
ZippyNH
Guessing you MIGHT be hearing a throwout bearing rattle....
Tensioner could be iffy/bad...that might let the belt move around and cause a rattle....
I'd play with it...
Old Sep 20, 2014 | 01:27 PM
Fatandre's Avatar
Fatandre
I'd play with it...
What does that mean?
Why should it be affected if I put on the A/C on or not?
Old Sep 20, 2014 | 09:56 PM
ZippyNH's Avatar
ZippyNH
Belt tensioner would be heard cause the tension/load on the belt changes with the compressor on....
I suggested that the throwout bearing might be the sound cause folks sometimes mistake the sound as being connected to other actions....
Old Sep 22, 2014 | 06:08 PM
Fatandre's Avatar
Fatandre
I know the throwout bearing is also that needs to be changed, but would that make the sound come when I put the A/C on and then go away when turned off?
Jim Ferrell
Oct 6, 2015 08:09 AM
eliseo1981
Sep 30, 2015 07:57 PM
aldito2
Sep 30, 2015 10:44 AM
Brochacho
Sep 29, 2015 10:24 AM
dragonby
Sep 25, 2015 08:10 PM
