R61 :: Paceman Talk R61 Cooper and Cooper S hatchback discussion NOT REPAIR RELATED Discussions.
R61 19" tire options
Old Sep 15, 2014 | 10:15 AM
Markbett's Avatar
Markbett
19" tire options
So I have already decided to do away with the run flats. Way too noisy. The question is can I increase the tire size at all? I would be interested in keeping the 19" rims, but maybe go with something a little wider and taller like 235/45/R19.
Anybody do this?
Old Oct 26, 2014 | 10:37 AM
bmwr606's Avatar
bmwr606
i have 18 inch oem wheels on my cm all4 with sport suspension
i went from stock 225/45R18s (25.9 inch OD) to 225/50R18s (26.9 inch OD) with no problems or rubbing
my winter tires are 205/70R16s (27.3 inch OD) on mini oem euro alloys, again no problems or rubbing
Old Oct 28, 2014 | 03:36 AM
ASKtheteach's Avatar
ASKtheteach
I went from the stock 17s with runflats to 19x8 wheels with 225/40-19 tires. This is the factory JCW size.
Old Oct 28, 2014 | 03:38 AM
ASKtheteach
Oops! Just realized that I commented in the Paceman section. I have a Countryman, but the wheels are the same.
Old Oct 28, 2014 | 07:35 AM
Markbett's Avatar
Markbett
Yeah, I have 19" rims and 225/40/R19 runflats, and I want t taller and slightly wider tire, I think the 235/50's will work (non-runflat). I think that will be a little more quite. I'd like to keep the 19's but if I have to I'll sell them.
Old Oct 30, 2014 | 06:56 AM
Those wheels are nice, One you switch to NON RF the ride will feel much better. I would keep it the same size tire.
These are very nice wheels for the CM or PM. After seeing them in person. Wow , very nice.
R134 MINI JCW Cross Spoke Wheel 19" (5x120) - Black Gloss Turned - Set Of 4
http://www.ecstuning.com/Search/SiteSearch/36116854451KT/
Old Dec 1, 2014 | 09:07 AM
Markbett's Avatar
Markbett
I was dragging my feet on changing out my tires, but after last weeks, snow storm that brought about 5" of heavy wet stuff to the Philadelphia area, and a near miss collision with a Fed-Ex truck, I have schedule the swap. Going with Michelin's Pilot A/S 3 all season 225/45/19 non-run-flat. The Pirelli’s that are on the car (second time I had Pirelli’s on a car that had zero grab in the snow) are POS in my opinion.
When I hit my brakes I was sliding directly for a parked Fed-Ex truck, 1/2 on the road, 1/2 off, I don't remember hearing or feeling the ABS kicking in (which has me a little concerned). Only when I took my foot off the clutch and brake, did all 4 wheels grab and slow me down enough that I could steer clear.
Can't wait for some new rubber
Old Dec 8, 2014 | 11:12 AM
You would be much better with steelies and some snow tires. You can fit the 16" MINI Factory silver steelies and save the nice 19" for summer.
https://www.northamericanmotoring.co...-steelies.html
We have matching the center caps linked also.
Then get a good set of snow tires and the Paceman will drive much better.
Old Dec 8, 2014 | 12:18 PM
Markbett's Avatar
Markbett
Thanks for the suggestion, I was actually considering changing the wheels, but to be honest, I barely have time to blow my nose, let alone swap out tires every season.
I went and got the all season Michelin's and man, WHAT A DIFFERENCE!!! Highly recommend scrapping the Runflats. Already drives like a different car. Don't know about the snow yet.
Old Dec 8, 2014 | 12:30 PM
Welcome. 19" and wide tires are hard in the snow, good you got the non RF. But Snows and steelies will make it a tank. I highly recommend those. If you have a set of wheels dedicated to snow and then summers all you have to do if flip the wheels.
Good luck and you when have a chance to drive with snow tires on a CM or PM i think you will like them.
minicoclub
Aug 25, 2015 09:07 AM
Emnotek
Aug 13, 2015 05:47 PM
Dashdog
Aug 10, 2015 06:17 AM
