R50/53 2006 r53 mcs
Old Sep 15, 2014 | 08:27 AM
cannovmj's Avatar
cannovmj
2006 r53 mcs
So I am picking up my R53 tomorrow and am so excited!(Pictures to come)!!
It is astroblack with white stripes on the bonnet and 70K miles.
With that being said, the mod-bug has already bitten me...While I dont have $10k to throw at the car today, I do have a decent budget to work with.
As far as first things on my mind, I am hoping to do this before the winter (as I live in Buffalo NY)
1.) cold air intake (not sure if I want to go Alta or Dinan)
2.) Pulley reduction (I do not plan to track the car, but am a spirited driver, so not sure if I want to do 15% or 17%? from what I have read, 19% is just unnecessary and carries a risk of belt damage. Also I have heard cost of getting this done is $160-200?)
After doing these light mods, I am debating what to do next...Not sure if I want to upgrade the intercooler(forge) or exhaust (Borla aggressive)..My concern with doing the exhaust now, is subjecting it to a Buffalo winter.
Finally, I know that the best torque/hp upgrades are a new cam and header.. problem is I am unsure of the costs to have this done? From light research I have found that both parts cost anywhere from $500-1000 each?
thanks and ill be sure to post pics tomorrow!!!
Old Sep 15, 2014 | 09:15 AM
bavmotors's Avatar
bavmotors
Congrats on the r53, I'm also from the buffalo area. Buffalo winters are actually a good reason to change your exhaust, as the stock systems tend to fall apart.
Old Sep 15, 2014 | 09:40 AM
cannovmj's Avatar
cannovmj
See I was worried that I would spend the $800 or the borla exhaust, then have it rust on me because of the winter. Though I am going to get the delta sonic unlimited car wash deal. Where in buffalo are you? Have you done the pulley replacement yourself?
Old Sep 15, 2014 | 09:53 AM
ZippyNH's Avatar
ZippyNH
Before you get your heart set on any specific part...check availability....
I like my dininan intake....but they went out of production a few years ago...so used might be your only option there...but very diffent sound than the Alta/Alta clone style units...
Borla exaust....some like the sound on a mini...but can be a bit fartish/ricy...listen to one first...check for highway drone too....warrenty is useless...trust me.
Stock exaust is stainless...it gets ugly...and the cans on the back have MILD STEEL heat shields that rust and fall off...but the actual muffler and resonator ARE stainless, as are the pipes...
Tip...the single sided ones tend to buzz and drone at highway speed...
For about $100+ you can get a duel muffler/two sided one that makes sound when you foot gets into it...but is quiet on a longer drive...still lots of choices...depends on your $$.
Old Sep 15, 2014 | 10:01 AM
cannovmj's Avatar
cannovmj
Yea wouldnt be completely against used CAI, but do like the sound of the Alta. And I have listened to a lot of the borla exhaust clips on youtube, and have liked the sound. It is a duel muffler exhaust, but like i said ijust dont want to have to worry about rust.
Old Sep 15, 2014 | 12:02 PM
cannovmj's Avatar
cannovmj
I also forgot to ask, after which mods is a tune absolutely necessary? I intend on getting a tune following CAI, exhaust, intercooler, and pulley reduction, but would prefer to wait to get it until I have completed all of those
Old Sep 15, 2014 | 12:17 PM
MINIAC's Avatar
MINIAC
You don't really need a tune after the mods you've listed. If you add a cam and larger fuel injectors then you'll need a tune.
Old Sep 15, 2014 | 12:24 PM
cannovmj's Avatar
cannovmj
OK awesome, thanks for the info. Would a tune be of any benefit one those mods are all in place?
Old Sep 15, 2014 | 12:35 PM
ashchuckton's Avatar
ashchuckton
Power is nice & an intake, exhaust & pulley (15% if you track it) will make it move nicely. An intercooler won't make you power, it will help you keep what you have on a hot day.
Before I'd spend a bunch on engine mods I'd tighten up the suspension. Handling is what these little cars are about.
Once you add your engine mods a tune will help you get the most out of what you have. If you tune & then add more parts you'll be tuning it again. Wait till you are done for your tune. I'd recommend RMW.
Old Sep 15, 2014 | 12:41 PM
cannovmj's Avatar
cannovmj
Yea every thing I have recommends RMW, just not sure where I would go to get it done.
I won't ever track the car, more NY daily driver, which is why I planned on doing all of the power increase, then suspension and sway bars in the summer. So if I'm not tracking, does that make an upgraded intercooler less worth it? And also should I go for the 17% or 19% pulley? Finally is a can really worth the investment? Once again new to mini s so I am not familiar yet. Thanks again!
Old Sep 15, 2014 | 12:54 PM
ZippyNH's Avatar
ZippyNH
Save your $$ on a gen1 intercooler....it is way down the list....$$ for performance... It is after a BIG VALVE HEAD (BVH) in my rough guess on cost per HP....
if you have 93 octane a 17% pulley is great for a daily driver, especially in a generally cooler area......if you live in a HOT area, and only have 90-91 octane...my gut has always felt 15% was a better choice......
Tune is not needed with a pulley, intake, and exhaust....
But it WILL add HP, tq, and the tuner can adjust some other items like DSC...
But I suggest you get to know your car....see if it has a pulley or a sway bar...maybe needs struts or strut tower work....
Heck...you may find the brakes were done with cheap parts, and need to freshen it a bit....
So I suggest you drive it for a few days...and choose!!
Lots of fun!!
Old Sep 15, 2014 | 12:59 PM
ZippyNH's Avatar
ZippyNH
One more thought....
A CAM tends to let the car make more power at higher rpms...like most mods...you must choose carefully to make the car perform the way you want, and not kill the in town performance...
Folks have made mini's into race cars...great at 6500 rpm...but sucks at 3200rpm in town....
The cams are typically sold in "street", aka more midrange, and race, more top end.....
Old Sep 15, 2014 | 01:57 PM
bavmotors's Avatar
bavmotors
I'm about 15 mins from east aurora in the country. I did the pulley myself yes, with the help of a friend. It's not too bad, pretty straightforward.
Old Sep 15, 2014 | 02:10 PM
cannovmj's Avatar
cannovmj
Oh ok, Im out in east aurora a bunch. I want to attempt to do the pulley myself but just worried I wont have all of the tools or the time to actually finish it hah. ill decide once i order the pulley
Old Sep 15, 2014 | 02:49 PM
bavmotors's Avatar
bavmotors
No special tools really, just the pulley puller, torque wrench with inch lbs and a belt remover. I think it can be done without the belt tool.
Old Sep 16, 2014 | 06:08 AM
Saltysalt's Avatar
Saltysalt
welcome to the crowd and the mod bug. my magnaflow has seen 2 winters, and has no rust, im here in NH, granted you guys get more snow than us! i love my alta CAI for the noise. they are easy to get, and theres a few on the marketplace right now for cheaper than buying new. first mod you should get is some snow tires, best thing ever! then CAI, exhaust and pulley. i havent stepped into the cam world yet, only because i havent had the time to work on my car. otherwise im waiting to tell thumper for the whole bundle. a tune isnt completly nessecary immediatly and not worth it till you get larger injectors, i already have these parts in my living room haha. just do your research when it comes to CAMs and BVH's if you get to that point. same with injectors
Old Sep 16, 2014 | 07:12 AM
cannovmj's Avatar
cannovmj
Awesome! Thanks for the response. Yea, I'm getting snow tires in the beginning of November then new wheels and tires in the spring time. And Yea I have been keeping my eye on the marketplace trying to find a Alta cai for the r53. And okkk, so no rust problems then huh? I might have to do the exhaust sooner than expected but yea those are all the things I want to do sooner than later, assuming I have time lol
Pics to come tonight!!!
Old Sep 16, 2014 | 09:57 AM
Saltysalt's Avatar
Saltysalt
no rust yet, eventually itll have to give to the new england salt! although it has that nice petine of brown from the heat =)
Old Sep 16, 2014 | 11:24 AM
Helix13mini's Avatar
Helix13mini
Well purchased: still the best MINI year available.
Old Sep 16, 2014 | 04:52 PM
cannovmj's Avatar
cannovmj
Mini has been purchased, pictures to come!!!!
Old Sep 16, 2014 | 04:55 PM
JABowders's Avatar
JABowders
Veteran: Army
Welcome to the MINIacs... I see the bug has not only bitten you, but jump on your back and is doing a little dance.
Motor on!
Old Sep 16, 2014 | 04:58 PM
bavmotors's Avatar
bavmotors
Look forward to possibly seeing it on the road.
Old Sep 18, 2014 | 03:37 AM
fastzombie's Avatar
fastzombie
I live in northern maine and I would imagine Buffalo roads are not the smoothest, so I would recommend a set of strut tower defenders.
For exhausts I use the Stratmosphere from Way Motor Works and really like the sound. Fitment was super and is dynamite.
Welcome to the modding club.
Melvinyip
Apr 17, 2020 09:28 AM
Steeroidz
Aug 29, 2018 07:41 AM
keck.j
Aug 18, 2015 08:18 PM
elightbo
Aug 17, 2015 01:50 PM
minipopkart
Aug 13, 2015 05:22 AM
