Funky electrical problems?
Old Sep 7, 2014 | 04:28 PM
znekcihc's Avatar
znekcihc
I have a 2006 MCS Automatic USA 91k mileage for 3.5 years originally bought at 45k mileage.
Ive had some funky electrical problems since I have bought the car. It started out with the stereo unit randomly restarting after beeping a couple times. Sometimes I start the car and the windows won't work (eventually turn on after a few minutes). Sometimes its the steering wheel radio control buttons work, but not properly. Sometimes I start the car and the tach, battery gauge, psi gauge don't work (eventually turn on after a few minutes). Sometimes When I turn off the car the PS fan stays on or even a random light. Sometimes the blinkers don't turn off after I've turned (only for a few moments then goes back to normal).
My battery is about a year old. It did just die a month ago from something being left on (not my fault). Maybe I need to replace it? I do have a MINI iPod adapter and has never worked properly. I tried to disconnect most of the adapter but left some wires in. When I first purchased the car I was upsold on an AMP. Little did I know it had the HK system in it. It took them 3 solid days to install just the AMP and it was a poor job and done incorrectly. The next day I got it all uninstalled back to stock HK. Perhaps this is a trickle down of electrical problems from the poor install?
In the past 300 miles the first video has happened to me 4 times. Now its getting worse. The 2nd video is just moments after the 1st video. Im just cruising at 70 mph on the freeway.
If you notice in the first video the tacho is bouncing from 2800-2600 rpm. I was in a smooth drive.
Today was the first time I lost acceleration speed from a dead stop to try and start going. All I have to do is turn off the car and turn it back on and everything goes away except the EP mode and Service engine light. After turning on and off the car 5-10 more times and random time is passed the EP mode and Service engine light go away and the car is back to normal.
Any suggestions or help is great!
Old Sep 7, 2014 | 04:29 PM
znekcihc's Avatar
znekcihc
FYI, the airbag senor is not part of this problem. That has been on since 50k mileage. Bad sensor Im told. Just don't want to fork over $1k to fix it.
Old Sep 7, 2014 | 05:47 PM
c0op3r's Avatar
c0op3r
I think I have read that its the Body Computer, have you removed the lower panel on the passengers side and seen if it ever got wet?
Old Sep 7, 2014 | 06:16 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
Do you have the power moon roof/sun roof in your car?
Old Sep 7, 2014 | 09:17 PM
ZippyNH's Avatar
ZippyNH
My suggestion....
Step 1...unplug the iPod adaptor....when they fail... Crazy stuff happens...
If issues remain...start looking at the bcm and wiring...
Old Sep 8, 2014 | 01:56 PM
znekcihc's Avatar
znekcihc
I do have the moon/sun roof.
Inspected bcm and looks clean as a whistle.
I uninstalled most of the iPod adapter. Not sure how to uninstall the rest as all the wires are integrated.
Battery is 1.5 years old. Was some minor corrosion on it. Cleaned it up. Do I just put a voltmeter to it and make sure it's stable?
Old Sep 8, 2014 | 01:58 PM
c0op3r's Avatar
c0op3r
Yes put the volt meter on it without starting the car, put the voltmeter where you can see it while starting the car and watch the voltage drop and the output after the car starts.
You should see something like 11.7 or better before starting, a drop to as low as 8 or 9v while cranking and 13.7 to 14.4 after running.
Old Sep 8, 2014 | 03:03 PM
znekcihc's Avatar
znekcihc
Battery checks out fine.
Old Sep 8, 2014 | 03:22 PM
Mib4840's Avatar
Mib4840
Have you tried resetting the ECU? I have had funky electrical things happen and the first thing I do is the reset. You can find the steps in the Forums area under 1st Gen MINIs in the ULTIMATE newbies DIY sticky (3rd sticky down). It's worth a shot.
Old Sep 8, 2014 | 03:30 PM
znekcihc's Avatar
znekcihc
I reset the ecu a few minutes ago. Well drive it around and keep you posted.
There is still 1 s video cable hooked up , does that come stock?
Old Sep 8, 2014 | 03:34 PM
znekcihc's Avatar
znekcihc
It's worth noting I have a parrot installed too
Old Sep 8, 2014 | 04:29 PM
ZippyNH's Avatar
ZippyNH
Nope...
I would unplug it from the BACK of the radio... Just like the iPod....they are connected to the cars data bus...when an item fails...well documented with the iPod adaptors, it scrambles signals...messing up unrelated items...
Old Sep 11, 2014 | 11:12 AM
znekcihc's Avatar
znekcihc
The entire parrot and iPod adapter has been removed. Still having problems.
Ecu has been reset multiple times.
Battery was tested and works great.
Bcm looks clean as a whistle.
I'm at a complete loss of what to do now?
Old Dec 9, 2014 | 10:31 AM
mdurando's Avatar
mdurando
Did you get this resolved?
Old Dec 15, 2014 | 09:44 AM
znekcihc's Avatar
znekcihc
Ive since had the Speedo Cluster, Key Ignition, and Tach replaced. I just got the car back a few days ago. Trying to put some miles on it to see if it has been fixed. Will update you as soon as I know. =)
Old Dec 15, 2014 | 11:50 AM
mdurando's Avatar
mdurando
Thanks, I look forward to your update.
Old Jun 12, 2015 | 10:02 AM
dacinokc's Avatar
dacinokc
I'm dusting off this thread, I am having very similar issues, the TPM light will pop on, and the car goes to EP transmission limp mode. I can turn off car, reset TPM and sometimes it works... Last night the Tach just stopped working, then popped back on once I was going. I read several things suggesting the Body ECU/CPU is the issue, but anyone else have similar issues?
Old Jun 12, 2015 | 10:17 AM
znekcihc's Avatar
znekcihc
The speedo, key ignition and tach were all giving off below spec voltages. They were replaced and have not since had any issues. Just issues with the Passenger Seatbelt sensor. But thats covered under a recall now. YAY! =D
Car is in shop now getting a Coolant Flush, Tranny Flush, Coolant Thermostat, and Tranny ThermoCooler replaced. =(
David.R53
Sep 1, 2015 06:51 PM
jesterofatlas
Sep 1, 2015 11:26 AM
Zettinger
Aug 25, 2015 04:04 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
