HELP! 2011 R56 won't turn over!
Old Aug 30, 2014 | 04:40 PM
MNMLST's Avatar
MNMLST
SOLVED: 2011 R56 won't turn over!
This morning I replaced front brake pads and a rear pad wear sensor that's throwing off a CC-ID 071. Afterwards, I tried to reset the service lights, following instructions stickied on this sub-forum.
I started the car and it started fine. But when the codes came back, I decided to go through the reset procedure again. Then, I tried to start the car again, but this time the engine didn't turn, lights flashed on and off and I heard "tick, tick, tick, tick..."
In addition to the CC-ID 071, CC-ID 275 also popped up all of a sudden.
What happened? I didn't even touch anything in the engine compartment?
EDIT: It was the battery. Replaced it even though the sight gauge is black, which means recharge, and Autozone confirms the it's bad.
I'm fortunate that it went out while I was working on it in the garage instead of in the middle of nowhere. But I'm still curious as to what have caused it to discharge.
Old Aug 30, 2014 | 05:08 PM
gregsmini's Avatar
gregsmini
MINI batteries can be disappointing. There have been many threads on here where folks work on their cars and have the problem you have. Put a charger on the battery for a few hours and then give it another try.
Old Aug 30, 2014 | 05:41 PM
AZdsrt's Avatar
AZdsrt
I was thinking the same, battery. Being a 2011 I'd bet it's the original battery? I would consider replacing it as it's close to EOL..
Old Aug 30, 2014 | 05:47 PM
MNMLST's Avatar
MNMLST
OK. Removed the battery so that I can get a better view of the sight gauge. It is black, which means charge. Should I recharge or replace?
Thanks for the replies!
Old Aug 30, 2014 | 05:50 PM
AZdsrt's Avatar
AZdsrt
While you have it out, take to an Autozone or equivalent and get it load tested. Here in hot AZ, once my battery hits 4 years, I just go ahead and replace it. I hate getting stranded..
09R56
Nov 16, 2022 10:49 AM
rikaro
Aug 7, 2021 02:33 PM
Zettinger
Aug 25, 2015 04:04 PM
patrioticmini
Aug 20, 2015 10:54 AM
xpunisherx
Aug 10, 2015 10:50 PM
