R50/53 A few issues with my Mini
Old Aug 28, 2014 | 07:09 PM
Rorshach84's Avatar
Rorshach84
Hey, everybody!
I've been a member for a while but, I haven't posted anything or uploaded any pics since I joined. Hopefully, the pictures I tried uploading twice will show up soon.
To get to the point, I have a minor issue with my 2003 R53. The airbag light has been on for some time despite not getting into an accident. The car was in an accident before my sister bought it in 2006 but, everything has been fixed since then.
Since I'm over 104k miles, I figure it's just one out of a few possible electrical issues. I have come here to try to get input from people who live with and have worked on Minis before.
What do you guys think?
Old Aug 28, 2014 | 07:30 PM
pav5069's Avatar
pav5069
I keep on hearing it could be the seat. Something about the car not knowing your sitting in it.
Old Aug 28, 2014 | 07:35 PM
Rorshach84's Avatar
Rorshach84
I've read a few posts that said that, too. Only problem is that I don't think they put the occupancy sensors in until 2005/6 and I own a 2003.
Something tells me that it could even be a blown fuse. Then again, electrical issues are never simple.
Old Aug 29, 2014 | 12:41 PM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
It could be the fuse (seen that). You could check that.
Old Aug 29, 2014 | 01:21 PM
kaveman's Avatar
kaveman
Check the connections under the seats. Some earlier cars had really short wiring to the seat, when moved they either separate the connectors or cut he wires. You may want to disconnect the battery before messing around with those connections. Once you repair, the light needs to be reset with an SRS tool, or the stealer can do it... For a fee...
Another 2 cents...
Kaveman
Old Sep 1, 2014 | 06:15 AM
fastzombie's Avatar
fastzombie
I just swapped out very beat front seats and made sure to fully disconnect the battery before disconnecting the seat connections. My understanding is if the seats are disconnected with the battery still attached, once the connections are reconnected you may or will have the airbag light pop up and will need to be reset by a technician with the appropriate tool.
Mine went fine but had I not disconnected the battery I probably would have had the airbag light problem.
I would bet you need to have the sensor reset by your Mini dealer.
09R56
Nov 16, 2022 10:49 AM
Svejk
Feb 24, 2019 12:18 PM
arf88
May 31, 2016 03:07 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
tippin
Aug 5, 2015 08:43 AM
