Suspension R53 PSS10/ 60MM Swift Spring ?s
Old Aug 27, 2014 | 11:26 AM
SPR CUPR's Avatar
SPR CUPR
Does anyone know what the "stock" spring rate is on the Bilstein PSS10s?
Looking to change to 60MM linear Swift Springs, and want to see what rate I should be looking for.
Also, does anyone know how aggressive of a spring the stock PSS10 valving can take? Say, if the spring rate is 200lb/in, and I push it up to 300, will it need to be re-valved.
Is there a general "If you increase be XXXlb/in....you need to re-valve?"
I'm trying to build something comparable to the WMW KW V2 set up (which I considered buying, but he wouldn't tell me the spring rate, and I'm not about to drop $2k on mystery springs) with the bottom adjustability of the Bilsteins.
Any and all help is appreciated.
Teh
Aug 22, 2022 04:37 AM
Mini7
Feb 2, 2016 07:52 PM
Manny_cooper
Nov 4, 2015 09:42 AM
Emnotek
Aug 13, 2015 05:47 PM
