R56 Ziza LED License Plate Bulbs ECSTuning flickering?
Old Aug 26, 2014 | 07:32 PM
mattjewell's Avatar
mattjewell
Bought these bulbs about 3 weeks ago, and now the drivers side is flickering.
Pulled the bulb out and flipped it 180 degrees and still flickering.
Not getting any code on the dash.
Awesome lights but something isn't right.
Any thoughts?
Old Aug 27, 2014 | 03:36 AM
Dustypants's Avatar
Dustypants
I had a couple bad ziza lights out of the box. A quick email to ECS and new ones were mailed free of charge. They are pretty rad about that stuff!
Old Aug 27, 2014 | 04:49 AM
Hello, Just contact our customer service, they can take care of you.
1.800.924.5172
customerservice@ecstuning.com
Also just check the terminals to make sure the prongs on the MINI are not corroded. Sometimes happens when the trunk grip light lens on your MINI falls off, exposing those prongs.
Old Aug 27, 2014 | 05:58 AM
mattjewell's Avatar
mattjewell
Thanks! Email sent.
Figured I would try anything before bothering ECS!
Dustypants: Did yours flicker?
Old Aug 27, 2014 | 06:28 AM
Dustypants's Avatar
Dustypants
Originally Posted by mattjewell
Thanks! Email sent.
nope, mine just straight died. When i popped it out, one side was toasted.
Old Aug 27, 2014 | 06:29 AM
mattjewell's Avatar
mattjewell
Well that was seamless, emailed ECS and within 7 minutes they already had another order setup and will ship today.
These guys are fast and very easy to work with!
Old Aug 27, 2014 | 06:42 AM
Grizld700's Avatar
Grizld700
Both of mine flicker when starting the car, I assume its part of the bulb check procedure the MINIs do. After about 5 seconds they stop. They've worked just fine for me.
Old Aug 27, 2014 | 06:49 AM
mattjewell's Avatar
mattjewell
I thought that was the original problem, but it happens all of the time. The contacts are extremely clean and no corrosion.
Old Aug 27, 2014 | 08:20 AM
"Both of mine flicker when starting the car, I assume its part of the bulb check procedure the MINIs do. After about 5 seconds they stop. They've worked just fine for me."
Yep that's separate thing, that's the LKM Light control module checking for power, bulb check procedure designed by MINI. Does it on all outside leds. Standard thing.
"Well that was seamless, emailed ECS and within 7 minutes they already had another order setup and will ship today.
These guys are fast and very easy to work with!"
Great thanks and glad we could help very fast.
Old Aug 27, 2014 | 08:23 AM
mattjewell's Avatar
mattjewell
Have you guys ever heard of this happening? Even after taking the bulb out and rotating 180 degrees?
Let's say when the replacement bulbs get here and the problem still persist, what do you think could be the issue?
Old Aug 27, 2014 | 08:30 AM
Nope, have not see that yet. Based off the right side bulb is ok and contacts are ok, from what you said. Looks like a bad bulb. I am glad we can help.
Old Aug 27, 2014 | 08:49 AM
mattjewell's Avatar
mattjewell
I guess we'll see!
Thanks again for quickly addressing the issue
minimofo
Nov 16, 2016 05:56 AM
nismo4life
Nov 4, 2015 09:18 PM
Aug 7, 2015 05:56 AM
