A/C recirc button shuts off in auto mode
Old Aug 26, 2014 | 12:56 PM
KilmerPT's Avatar
KilmerPT
I have auto A/C in my 2013 R56 JCW and for some reason the air recirculation button will shut itself off after about 10-15 miles of driving during my commute to/from work. I drive about 33 miles one way and always have to push the button back on twice during my commute. Dealer says they could not replicate the problem and is normal because the car will want to do what it wants when on auto mode. However, I never had this problem when I had my 2011 MCS. Just wondering if someone has experienced something like this and would chime in. Thanks!
Old Aug 26, 2014 | 12:59 PM
cerenkov's Avatar
cerenkov
Mine has done this. But I almost never have it in recirc, only when behind a bus, diesel, etc.
Old Aug 26, 2014 | 01:02 PM
UCProf's Avatar
UCProf
I have a 2013 MCS with a manual AC system and the recirc. button turns off after sometime when I use it. I have to kept pushing the button to keep it on. Other than that, Sully is running fine.
Old Aug 26, 2014 | 01:17 PM
taveanator's Avatar
taveanator
The manual recommends that you not use recirc for extended periods of time because the air quality starts to degrade the longer you have it set to recirc. I'd imagine there is some sort of timer (in both auto and manual mode) that limits the time you can have it set to recirc.
Old Aug 26, 2014 | 03:10 PM
KilmerPT's Avatar
KilmerPT
Thanks to everyone for chiming in so quickly. At least I know my car isn't the only one that behaves like this. I usually prefer to have the recirc button on due to most of my commute passing thru agricultural fields. I guess I will just continue to re-push it as needed.
patsum
26
May 29, 2021 06:29 PM
molala
Oct 2, 2015 01:53 PM
schwac2
Sep 10, 2015 07:24 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
renchjeep
Sep 6, 2015 01:54 PM
