Coolant Bleeder Screw Location on Base Motor?
Old Aug 8, 2014 | 06:19 PM
Kimbo80's Avatar
Kimbo80
Hi everyone! Can you tell me the location of the bleeder screw location on the base motor? Instructions I have found on the web are only for the Turbo. I have been topping off my coolant, and the coolant level in the expansion tank has been slowly going down. I am going to try to burp the system. I hope it's not the thermostat, because this would be my second one already, and I am only at 25k on the odometer. Thanks.
Old Aug 8, 2014 | 09:21 PM
cenotaph's Avatar
cenotaph
The bleed screw is part of the thermostat housing. It's on the driver's side of the engine, and is kind of buried by the hoses there. It's number 8 in this image. When installed on the car, it should be closer to the center of the engine bay than the side.
Old Aug 9, 2014 | 07:29 AM
Kimbo80's Avatar
Kimbo80
Awesome! Thanks for the tip and the diagram. It was really hidden in there.
Old Aug 15, 2014 | 06:39 AM
Long Phillips head screw driver will work, that its above #8. Don't back it out all the way, it then pops out and it can fall on the thermostat housing crevices and then its a pain to fish out. Do it a little and back it out till you see the coolant spill out or bubble out.
Cereall
Sep 5, 2019 06:05 PM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
minipopkart
Aug 13, 2015 05:22 AM
Gipper
Aug 8, 2015 05:39 AM
joelcseymour
Aug 7, 2015 12:43 PM
