Navigation & Audio New aux input install - but power issues?
Old Aug 4, 2014 | 09:34 AM
FreudsMomsRage's Avatar
FreudsMomsRage
I've successfully installed the aux input and my tablet plays music through it like a champ - except when the USB power is plugged in. I have a regular USB car charger with the standard Samsung USB cable, and when it's unplugged the AUX option shows up on the head unit and things work great. As soon as I plug in the power, though, the sound stops and AUX is no longer an available option.
Anybody have any ideas?
Pic for the curious. I decided to put the input down below the center control cluster in the middle of that little pop-off panel. You can barely see where the green 1/8" is plugged in behind the charger. The whole install took less than 20 minutes.
Attached Thumbnails New aux input install - but power issues?-minisoundsetup.jpg
Old Aug 4, 2014 | 10:26 AM
rkw's Avatar
rkw
It's a common issue. You'll need to put a ground loop isolator like this (or similar) between the device and aux-in:
Amazon.com: PAC SNI-1/3.5 3.5-mm Ground Loop Noise Isolator Works with iPod/Zune/iRiver and Others: Automotive Amazon.com: PAC SNI-1/3.5 3.5-mm Ground Loop Noise Isolator Works with iPod/Zune/iRiver and Others: Automotive
For more information, search on this forum for "ground loop isolator".
Old Aug 4, 2014 | 10:28 AM
FreudsMomsRage
Originally Posted by rkw
It's a common issue. You'll need to put a ground loop isolator like this (or similar) between the device and aux-in: Amazon.com: PAC SNI-1/3.5 3.5-mm Ground Loop Noise Isolator Works with iPod/Zune/iRiver and Others: Automotive
Thanks!
Old Aug 15, 2014 | 07:44 AM
Zenoches's Avatar
Zenoches
Thank you for the post and the answer. Mine was doing it too and I thought I was going mental.
surfblue
Oct 24, 2018 01:20 AM
squawSkiBum
Oct 2, 2015 09:21 AM
jeffbeckhudd
Aug 29, 2015 09:11 PM
