Suspected oil pump solenoid leak - confirm?
Old Jul 29, 2014 | 06:32 AM
Summons's Avatar
Summons
So...
Routine inspections led me to look at a oil leak that has started on the right side if the oil pan.
Pictures are aft looking forward and up at the oil pan right side area.
I suspect that's the oil pump unloading solenoid?
12 MCS-m with 52000km on it.
Sigh...
Old Jul 30, 2014 | 12:48 PM
cccplus's Avatar
cccplus
yes. it's a common problem for 2011+
Old Aug 2, 2014 | 02:24 PM
AZdsrt's Avatar
AZdsrt
Ditto. I just had my '12 replaced under warranty. The also replace the wire harness..
Old Dec 17, 2014 | 08:33 PM
justawatcher's Avatar
justawatcher
Does it hurt the engine when the solenoid control system fails? (due to module failure/ wicked oil)
Old Dec 18, 2014 | 08:30 AM
u238's Avatar
u238
Yep, that's it. Mine is leaking too. Apparently it's not the solenoid that fails, it's the whole DME and wiring harness due to oil wicking into it and causing strange problems.
Old Jun 3, 2018 | 05:20 PM
fladale's Avatar
fladale
I have a 13 jcw roadster with the same leak. What is the repair? I see a gasket ring and a cover plate where the wires exit the block that are available from mini.
Old Dec 19, 2020 | 09:18 PM
joedotmac's Avatar
joedotmac
I just had this repair done on a '11 R56 MCS. Job called for four parts.
(1) 11-41-8-609-973 Repair kit for wire
(1) 12-51-8-626-764 Adapter for oil pump
(2) 61-13-8-353-748 Cable connector
(2) 61-13-1-379-833 Shrinking hose
Etrain
16
Aug 5, 2024 04:37 AM
TREX
Nov 2, 2019 07:31 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
pocketmaster
Aug 6, 2015 01:41 PM
kwijmbo
Aug 5, 2015 09:00 PM
