Suspension Coilover question
Old Jul 28, 2014 | 08:30 AM
miniSherlock92's Avatar
miniSherlock92
Coilover question
Will r50/53 coilovers fit an r56? Just coils and spring set up with r56 mounts. The setup is almost identical.
Old Jul 28, 2014 | 11:37 AM
v10climber's Avatar
v10climber
I believe the front top mounts in the R53 are rotated compared to the R56 upper mounts. It might work if you used R53 upper strut mounts. IDK about the rest of it though.
Old Jul 28, 2014 | 01:11 PM
1qwkmini's Avatar
1qwkmini
Different (r56) front top mount/camber plates required and the rear tapered seating washer from the rear R56 shock. If you look at the 2 rear shocks you will see that the R56 has a tapered section that fits directly in to the rear control arm. The conversion piece/washer is available if you look around or if your R56 shock are shot you can cut that portion off and have it machined flat or maybe with a grinder/belt sander if you are careful.
Old Jul 29, 2014 | 03:11 PM
miniSherlock92
So the actual shock bodies them selves are the same, besides on the rear, the lower alignment spacer? I'm just curious since I came across a deal on fk coilovers but they're for an r53. I have r56 mounts for front and rear and will get camber plates for the front in a little. It might be worth jumping on.
miniSherlock92
Thank you
Old Jul 29, 2014 | 03:17 PM
1qwkmini's Avatar
1qwkmini
They should fit with the above mods..I run R56 kit on my R53 (with R56 aluminum rear trailing arms) only issue seemed to be that the this particular kit (eibach) has long rear shocks compared to my Megan coilovers.
donniedarko
Oct 21, 2015 01:15 PM
molala
Oct 2, 2015 01:53 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
RIchard Nguyen
Sep 6, 2015 07:21 PM
Ryan Caballo
Sep 4, 2015 12:20 PM
