R52 Power Steering Cooling Fan Question
My 05 (11-04) R52 has a bad PS cooling fan. Pictures of replacement fans show a small rectangular device near the power connector. My old fan does not have this thingy. Can anyone tell me what it is?
Hello,
Here is a thread with some more info on the power steering fan. The older original ones don't have the little built in fuse/ resistor. Newer ones do. They all get the newer one when replaced. We have some options here:
https://www.northamericanmotoring.co...ng-issues.html
You can buy a "bare" fan....and reuse the metal part....
Later 2005+ mini's had the fans screwed on...yours is likely rivited on...drill them out, and use 4 sheet metal screws to mount the new one....about 5 minutes...
IMO buy a fan with the box...mine was the same...bet the box is a thermal fuse of some types...early minis seem to have s FIRE issue...but changes in mid 2005 seemed to fix the issue....
Just use a computer fan!
https://www.northamericanmotoring.co...-pump-fan.html
jk, I wouldn't do that.
You are welcome. Read through my link above and check everything out while you are in there. Good maintenance to check things out.
Get & keep this kit for when the PS system finally fails & when warranty runs out:
http://www.condorspeedshop.com/colle...teering-delete
Etrain
16
Aug 5, 2024 04:37 AM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
