R50/53 how to seal main bearing ladder?
Old Jul 25, 2014 | 07:05 PM
David.R53's Avatar
David.R53
Hi -
Getting ready to start buttoning up my r53 after recovering from a spun big-end bearing. I would like to hear others experiences on using sealant (or not) on the metal-metal seal between the main bearing ladder and the block.
I don't want it to leak and don't want to mess up my main bearing clearances! Caught on the horns of a dilemna!
I was considering the "light" version of hylomar as being well regarded and thin enough to (hopefully) not mess with the tolerances.
Thanks,
David
Old Jul 25, 2014 | 07:13 PM
David.R53's Avatar
David.R53
Also saw positive reviews for this stuff (which I haven't used before) - Permatex Aviation Form-A-Gasket No. 3.
Old Jul 25, 2014 | 08:26 PM
cerenkov's Avatar
cerenkov
I've heard of people using hondabond.
Old Jul 26, 2014 | 05:49 PM
jamez's Avatar
jamez
Be very careful on the type of sealant you use for the bedplate. The TIS specifies an anaerobic loctite number that has been discontinued - but replaced with another if you do some research.
DO NOT USE AN RTV sealant! The engine will leak like a sieve.
Old Jul 27, 2014 | 07:17 AM
David.R53's Avatar
David.R53
Thanks for the heads up!
I discovered those ebay BMW TIS discs include records for R53!
So, I was able to read the appropriate TIS.
The version I read says seal with Loctite 518 (and shows a picture of where to put it, so worth checking it out for anyone else trying to do this).
Loctite 518 does seem to be available, so all should be good.
QuickCooper
Dec 29, 2016 06:46 PM
boholio
Nov 9, 2015 03:50 PM
wyliec0y0te
Sep 15, 2015 01:13 PM
Septimusminious
Sep 14, 2015 08:47 PM
Sep 3, 2015 02:06 PM
