Worn out tire
Old Jul 22, 2014 | 11:02 AM
sbninja's Avatar
sbninja
Worn out tire
I Admit not rotating the stock contiprocontact ssr 195/55R16 's on my 2013 Coupe S. My left front tire is worn down to just about the wear bar:( All other tires have plenty of tread. I have 27,000 miles on them. The right front was replaced due to a pot hole blow out:(
What would you do?
Replace all tires with non run flats?
Replace just the one with new?
Replace just the one with a used off eBay?
Old Jul 22, 2014 | 11:16 AM
JAB 67's Avatar
JAB 67
No-brainer - a used one off eBay.
Old Jul 23, 2014 | 01:48 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
http://www.ebay.com/itm/NO-PATCH-95-...a7b421&vxp=mtr
Old Jul 23, 2014 | 02:22 AM
deovolens's Avatar
deovolens
Never put run flats on it, I would replace the two front tires with new ones.
Old Jul 23, 2014 | 06:51 AM
Fly'n Brick's Avatar
Fly'n Brick
+1...I'll finish the sentence...then when the rear tires need replaced move the front ones back and put the new ones on the front. The better two of the four should always be the drive tires. Alternatively, replacing all four then rotating them EVERY 5K miles is the optimum option.
Old Jul 24, 2014 | 01:24 AM
bmwr606's Avatar
bmwr606
per ALL tire manufacturers and tirerack.com (watch their video) if replacing only 2 tires put the new tires on the rear axle so that the front axle will lose traction (understeer) before the rear axle (oversteer) in adverse conditions
the average driver can survive understeer but will spin off the road in oversteer in adverse low traction conditions
Old Jul 24, 2014 | 06:55 AM
Fly'n Brick
Interesting, I was always told to put the new ones on the end where the power hits the road, told being the operative word. Of course that was as it related to the Detroit iron family sedan battle cruiser well before the days of MINI. I'll go visit tire rack and get re-educated.
Old Jul 24, 2014 | 07:24 AM
Alex@tirerack's Avatar
Alex@tirerack
Here is a link to the article.
Old Jul 24, 2014 | 07:46 AM
chappybmode's Avatar
chappybmode
hmm i always replace the front and then rotate...so that way i always have more grip on the drive tire. Seems to wear better to. Im not a tire pro though. Just read the article, and it makes sense. But what about acceleration around a wet corner, wouldnt you want the grip on the power wheel?
Old Jul 24, 2014 | 08:37 AM
nkfry's Avatar
nkfry
I would recommend replacing all 4 at the same time, followed by a quality alignment. Mixing runflats and non runflats gives an unpredictable ride and handling in my experience. Try to stick to a rotation every oil change (every 5,000 miles).
The ride improvement by going with a traditional tire over a runflat will be quite noticeable, and you won't bend wheels due to the runflats being so stiff anymore.
I will however recommend you carry a spare if/when you ditch runflats: http://www.detroittuned.com/mini-cooper-spare-tire/
Personally, I've always run the best tires on the front of the vehicle, regardless of FWD or RWD, but to each their own.
Nick
Detroit Tuned
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jul 24, 2014 | 08:40 AM
deovolens's Avatar
deovolens
The rear tires don't have traction, they just have to follow (FWD)
We speak here for normal people driving on a normal road.No rally pro's.
The ESP helps here a lot to eliminate any problems.For FWD the best tires have to be on the front.Just my 2 cents and 50 years of driving experience.
Old Jul 24, 2014 | 02:06 PM
Alex@tirerack
I 100% agree.
When you lift off the gas, momentum shifts forward. The rear of the vehicle was initially lighter in the rear end than the front. If the rear of your vehicle doesn't have equal or better traction potential than the front tires, your setting yourself up for some serious oversteering. Rally pro's might love this but it is not as easy to drive as understeer for most people. Just an example.
Old Jul 24, 2014 | 02:13 PM
bmwr606's Avatar
bmwr606
I 100% agree with Alex ... best tires on rear axle ... one oversteer in a panic situation in wet or slick conditions will convince you, if you survive
Old Jul 25, 2014 | 12:36 AM
deovolens's Avatar
deovolens
There is only one solution :good tires on 4 wheels and let the ESP do its job.Saving on tires is not done.
When I was young "heel and toe" and using a hand brake to provoke a drift was done in rally situations.Now the modern Mins are much more safe and faster if you drive in an intelligent way.
Old Jul 25, 2014 | 01:00 PM
afadeev's Avatar
afadeev
+1
Get another same make/model/wear rate tire off eBay to finish off the set you have on right now.
THEN migrate to proper non-runflop tires (better traction, better ride, better quality tire, lower price point).
Too many others have expressed opinions on rotation, nothing more to add other than: you can do the smart thing, or you can do the lawyer-approved thing. Do what makes sense to you.
a
Old Jul 27, 2014 | 08:46 AM
Aric Rudden's Avatar
Aric Rudden
Just replaced factory 205/55/17 run flats on 2012 Countryman with 225/50/17 Bridgestone Drive Guards. What a huge difference! They drive smooth and quiet like regular radials but you still have security of a run flat.
Waszak
Oct 21, 2017 05:55 PM
dpike
Sep 12, 2015 08:19 AM
Ntety
Sep 2, 2015 08:39 PM
