Navigation & Audio Gen 1 H/K amp - lucky me
Old Jul 19, 2014 | 11:24 AM
JAB 67's Avatar
JAB 67
Original owner 2004 R53 w/ H/K. Years ago when reports of amp failure started to become common I snatched up a good one that somebody had removed during an aftermarket upgrade. Paid $100. Yesterday after 10+ years and 135K miles my original amp failed. Swapped in the replacement and all is good.
Old Jul 20, 2014 | 08:10 AM
joylove's Avatar
joylove
Your old one - would you be willing to open it up and post good quality photos for investigation for the greater good?
Old Jul 24, 2014 | 07:36 PM
Lucky 13's Avatar
Lucky 13
Here they are...
-1 -
- 2 -
- 3 -
- 4 -
- 5 -
- 6 -
- 7 -
- 8 -
- 9 -
- 10 -
- 11 -
- 12 -
- 13 -
Old Jul 25, 2014 | 07:43 AM
joylove's Avatar
joylove
In the first image, the row of vertical IC that bolt to the chassis wall and heatsinks are the amp power FETs.
Is the one on the bottom left cracked?
Old Jul 25, 2014 | 08:24 AM
Lucky 13's Avatar
Lucky 13
Here you go... I've updated my prior post with more daylight photos. Let me know if you need something else.
I have some basic electronic tools also like a multimeter.
Old Jul 25, 2014 | 09:14 AM
joylove's Avatar
joylove
Thanks, did you get a second to check the chip I mentioned for damage?
Old Jul 25, 2014 | 09:17 AM
JAB 67's Avatar
JAB 67
I remain perplexed that no one has found the explanation for these failures; must be a common fault, as everyone's description is the same.
Old Jul 25, 2014 | 10:07 AM
Did you get the loud beep allot before it died ?
Old Jul 25, 2014 | 11:03 AM
Lucky 13's Avatar
Lucky 13
No sorry, I don't know exactly which one you are referring to. But I can assure you that I can't see any physical damage or burnt component on the board.
Nope! I would more call it... sudden death. I recall having problem with the AUX mode to become invisible while playing music. I had to power OFF the radio to regain access to the AUX mode.
Old Jul 29, 2014 | 10:39 AM
joylove's Avatar
joylove
This is the thread I was looking for. A totally dead amp was a SMPSU.
My girlfriend's mini cooper amp recently died after being stored for a while. Basically the head unit would power on and act normal, but nothing would come out of the speakers. I heard people also having the amp cut in and out everyonce in awhile. After some research I found this hardon-kardon amp costs $1050usd new and $500usd used. Obviously replacing the whole head unit and bypassing the amp would cost less than either solution. Being the hacker type I figured I would try to fix it myself. After fighting it for a few days I finally found the issue. It was in the 1.2v switch mode power supply. The switcher had died and it was not supplying power to the SHARC DSP's core. The part was ST's L5973D, digikey part number 497-4566-1-ND. This is what died in her amp, your's may be different.
Replacing this part should be done with someone will a lot of surface mount experience. The die pad is connected to the ground rail and requires a smd heat gun to remove and replace.
Here are some specifics:
After reading forums I found that her amp of her 2006 Mini Cooper Convertable was located under the passenger seat. With the car off, remove the seat with a Torx socket. Then remove the 4 screws holding the amp case into the cavity. From there pull out the amp case, then remove the torx screws holding the top to the basin. Next remove the amp from the case by unbolting the 3 10mm nuts. At this point I would put all the screws back into the basin, and the car since you will probably need a bit to properly diagnois and repair the amp. Also, keep the amp cable out but put the seat back in and re-attach all the cables (BEFORE YOU TURN THE CAR ON!) If you do not do this you will need someone with an OBD connector to reset the airbag warning.
Now that you have the amp out you can remove the electronics by taking unscrewing the connector side, and the amp circuit should slide out. You should see the the two 470uh inductors. 1 is a 3.3v and the other is 1.2v. If the 3.3 volt is bad it will make the 1.2 volt bad since it feeds it. You should be able to hook up the amp in the car and test that this switching is working properly. You also can attach 12v to either side of the diode on the connector board in your lab. If you don't see 1.2v and or 3.3 volts you know where your problem lies. On my circuit I was not seeing the 1.2 switcher pulsing.
Hope this helps out the engineers out there locate their problems with this troublesome amps.
-Trunk
Source
Old Jul 29, 2014 | 11:11 AM
JAB 67's Avatar
JAB 67
Smpsu?
Old Jul 29, 2014 | 02:33 PM
Switch mode power supply unit ?
Old Jul 29, 2014 | 02:45 PM
Lucky 13's Avatar
Lucky 13
«...You should see the the two 470uh inductors....»
I read that too, but which are the inductors? I tried to match the parts he is talking about but could not find one on my board.
If someone can point me which ones, I will test those on my board.
cub4bearindiana
Oct 2, 2015 09:45 AM
Alpha Motoring
Oct 1, 2015 10:30 AM
patsum
Oct 1, 2015 06:33 AM
Emnotek
Sep 29, 2015 07:37 AM
