Help with OBDII codes after a short circuit
Old Jul 18, 2014 | 11:21 AM
Tech69's Avatar
Tech69
Hi I have a problem with my mini cooper 1.6 turbo N18 engine R56, shorted out just change the blown fuse and lit the engine .... good to try to start the engine indications appeared engine breakdown,
codes:
P16E8
P1644
P0193
P12A4
Old Jul 20, 2014 | 07:47 AM
Bigdaddy0128's Avatar
Bigdaddy0128
Are the codes the same for an N14 and N18?
Here are the codes out of the Bentley
P16E8 - DME, internal fault, monitoring of 5V sensor power supply 2: Voltage outside valid range
P1644 - Throttle valve adaptation relearning lower mechanical stop
P0193 - Rail-pressure sensor, electrical: Short circuit to positive
P12A4 - no such code
AdrenaliNate
Nov 4, 2015 07:26 PM
sdotbailey
R55 :: Clubman Talk (2008+)
Sep 16, 2015 09:03 AM
MasterShaftner
Sep 4, 2015 03:52 PM
boostedhaze
Sep 2, 2015 07:56 PM
bcman
Aug 28, 2015 04:47 PM
