R50/53 Control arm bushing gap photo
Old Jul 4, 2014 | 02:07 PM
GoThingNC's Avatar
GoThingNC
After cleaning the Mini today I noticed there seems to be a gap between the collar and control arm bushing.
Is it about to pop out or can I wait a little bit longer before replacing?
Old Jul 5, 2014 | 05:15 AM
jwh's Avatar
jwh
I don't think there is any way for it to pop out unless the ball joints are broken or the arm is bent.
Old Jul 5, 2014 | 06:29 AM
GoThingNC's Avatar
GoThingNC
OK, Thanks !
Old Jul 5, 2014 | 07:30 AM
jwh's Avatar
jwh
By the way, that bushing just presses into the mount. So if there is a gap it's probably due to a worn inner ball joint. I'd plan on replacing the bushing, the inner, and the outer/lower ball joints at the same time. It's all easy enough once you get the lower-arm off the car.
I wouldn't wait too long, this must be wreaking havoc with your handling!
Old Jul 6, 2014 | 09:32 AM
GoThingNC's Avatar
GoThingNC
Handling is spot on, does not drift and zero vibration from the wheels.
Old Jul 6, 2014 | 04:56 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
"If it ain't broke, don't fix it".
Old Jul 7, 2014 | 06:03 PM
Domiracer's Avatar
Domiracer
Gap looks about right
Old Jul 8, 2014 | 04:37 AM
GoThingNC's Avatar
GoThingNC
Thanks everyone !!
I can now motor on....
W0TM8
Dec 19, 2019 07:50 AM
Mini7
Feb 2, 2016 07:52 PM
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
