R50/53 Tie rods
Old Jul 2, 2014 | 08:05 AM
bcgreen's Avatar
bcgreen
Tie rods
I've noticed there is quite a difference in pricing for tie rods - OEMS for around $65 and $106 from some other suppliers mentioned here. Popular outside supplier has them, from Beck, for $128.
Any opinions?
Old Jul 3, 2014 | 11:57 AM
mrbean's Avatar
mrbean
Lemforder for $65.
They're OEM. The only difference is the box they come in.
Old Jul 3, 2014 | 12:01 PM
bcgreen's Avatar
bcgreen
Originally Posted by mrbean
Lemforder for $65.
Ordered, thanks.
If you've taken a tie rod assembly off before, did you have a 34mm wrench in your tool box? That's the only hang-up for me because that's not a normal size wrench I would normally carry.
Old Jul 3, 2014 | 01:47 PM
mrbean's Avatar
mrbean
Originally Posted by bcgreen
Ordered, thanks.
I have a set of these which is what I used. One of my favorite hand tools in the toolbox.
http://www.knipex.com/index.php?id=1...500&artID=2999
Old Jul 3, 2014 | 03:29 PM
bcgreen's Avatar
bcgreen
Looks like regular pliers except those curved nose ones.
Old Jul 3, 2014 | 06:41 PM
mrbean's Avatar
mrbean
Very different from regular pliers. Try 'em.
Old Jul 3, 2014 | 08:33 PM
matt922's Avatar
matt922
This is going to sound kind of crude, but a pipe wrench works pretty well on tie rods. I changed them on my buddies while the subframe was down and it was quite easy. Make sure to order a new set of boots.
The knipex plierswrench are pretty nice too, i've been eying them for a while now.
Old Jul 4, 2014 | 09:52 AM
bcgreen's Avatar
bcgreen
They must be pretty narrow to get in there. They look like channel locks. I have a couple of channel locks, do you think those would work, considering they look very similar?
I have someone coming by the house tomorrow who useto be a mechanic working on Minis, so he will have something to do the job. Will let you know what he suggests. At least I don't have to shell out money for a tool I will use perhaps use once.
Old Jul 4, 2014 | 09:57 AM
bcgreen's Avatar
bcgreen
I don't want to take down the subframe if I don't haveto. Knowing my luck if I did go that route, I might run into another problem, especially since I haven't done this job before, I don't know what problems might crop up.
Old Jul 5, 2014 | 11:42 AM
bcgreen's Avatar
bcgreen
Okay, I had the mechanic bring over his Snap-On pliers to get to the nut.
He accessed it not through the gap, but over the top. The pliers look like long handled chanel locks. There was just enough wiggle room to break the nut. So that's how he useto do it.
In order to remove the old tie rod, you need to access the large ball joint under the boot. The easiest way to do this is through the gap between the control arm and the subframe. With both hose clamps removed, pull the boot back and turn the steering wheel to position the nut in between the gap
You will need a thin, 34mm open end wrench to remove the tie rod end. Unfortunately, a crescent wrench wont work here unless you also unbolt the inboard ball joint from the subframe and also the outboard ball joint from the wheel housing. This will allow you just enough room to slip a crescent wrench or a standard width open end wrench in.
Fordgt4
Oct 10, 2015 10:42 AM
buggyeye401
Oct 1, 2015 01:22 PM
SneedSpeed
Oct 1, 2015 03:01 AM
micromini234
Sep 30, 2015 07:36 PM
Emnotek
Sep 29, 2015 07:37 AM
