R50/53 Body panel question
Old Jun 25, 2014 | 06:37 AM
Mib4840's Avatar
Mib4840
Body panel question
I am looking to install the JCW Carbon Fiber wing on my MINI. I have the S spoiler on it now. What I want to do is leave the S spoiler attached to the panel on the boot and take that panel off. I want to buy an R50 panel to mount the JCW wing on so I don't have to plug/cover the holes left by the S spoiler. Is it possible to replace just that panel or do I have to buy the entire boot lid? Also, is the R50 and R53 panel/boot lid the same? I have looked at RealOEM with no luck and searched the Forums.
Old Jun 28, 2014 | 06:24 AM
Milpol's Avatar
Milpol
Looking at RealOEM the trunk is the same part ! so if you replace it with an R50 you will find it will fit fine.
See if you can buy a second hand complete unit and get it resprayed, I have a 2002 R50 and am in the process of swapping it out with a 2005 MCS unit with the factory spoiler, all I will need to do is swap out the wiring once its finished and re attach the hinges and gas shocks.
Old Jun 28, 2014 | 07:51 AM
Mib4840's Avatar
Mib4840
Thank you! I've called around to the junk yards and they don't have a clue what I am after. I finally found a boot that the guy said was damaged on the bottom so he would take whatever I wanted off of it. It has the Union Jack on the part I need so it may be black underneath.
Old Jun 28, 2014 | 06:27 PM
Milpol's Avatar
Milpol
Cool, I was lucky to obtain an undamaged Boot but the wiring loom had been cut just inside of the roof so I will need to transfer the original harness when I swap the lids over. My mini is BRG where the boot I got from the wreckers is Blue with Silver so its just a case of stripping the paint back to respray it to match the car.
eatsleepautox
Oct 30, 2015 06:46 AM
Sailorlite
Sep 21, 2015 12:00 PM
chicohuahua
22
Aug 20, 2015 11:17 AM
Emnotek
Aug 13, 2015 05:47 PM
