FS:: R56 JCW Springs (Red) + Front Sway Bar NEW (NYC)
Old Jun 24, 2014 | 03:57 PM
BAMini's Avatar
BAMini
Category: Suspension
Price: $350
Item Condition: Brand New
I have a brand new set of Red JCW Springs I bought for my 2012 Mini Cooper. But I have decided not to upgrade my car, so they are for sale! I had them ordered by a dealership who had to order them from Germany. I am located in NYC.
$275 + Shipping.
Attached is a picture of two of the springs and all of the boxes. The other two are still in their original packaging from Germany.
Part#s
33536782731 x2
31336782727 x2
I also have a brand new JCW front sway bar (including new appropriately sized bushings) for sale.
$100 + shipping.
Part# 31356778646
bushing# 31356758302 x2
Both for $350 + Shipping
Attached Thumbnails R56 JCW Springs (Red) + Front Sway Bar NEW (NYC)-jcwsprings.jpg   R56 JCW Springs (Red) + Front Sway Bar NEW (NYC)-jcwfrontswaybar.jpg
Old Jun 24, 2014 | 08:57 PM
Variance Doc's Avatar
Variance Doc
Are these springs for a hardtop with or without a sunroof?
Old Jun 25, 2014 | 08:51 AM
TheBingoBalls's Avatar
TheBingoBalls
How much (approx.) would it cost to ship to Toronto?
Old Jun 25, 2014 | 09:19 AM
BAMini's Avatar
BAMini
They were ordered for a hardtop without a sunroof. However they will fit any R56. They will also lower any non-JCW package car and stiffen it over stock or sport springs.
I tried doing a quick search on UPS, and probably around $80 - $90
Old Jun 25, 2014 | 09:44 AM
diffuser1977's Avatar
diffuser1977
Do you have a picture of the sway bar?
Old Jun 25, 2014 | 10:16 AM
BAMini's Avatar
BAMini
I uploaded one on the first post. It's brand new, never installed.
The two bushings for the bar are also in the picture. (in the plastic)
Old Jun 25, 2014 | 11:35 AM
Variance Doc
You must keep in mind that the spring rates *are* different for different optioned cars, e.g. sun roof vs. no sunroof. This *will* effect the handeling of the car if the wrong spring rate is used. BTW, can you give me a shipping quote to 28203? Note I did not ask for a range, but an actual number.
Old Jun 25, 2014 | 11:48 AM
BAMini's Avatar
BAMini
Yes, I understand that they have different rates.
There are no "wrong" spring rates, only that which matches your intentions for how the car should handle.
Do you have any published numbers on those spring rates?
Shipping to 28203 is $35
Old Jun 25, 2014 | 12:01 PM
Variance Doc
Hmm, I don't know anybody who whould want to *decrease* the handeling of their car. But back on topic.... The spring rates are the million dollar question - nobody has published any reliable rates. Pm'd you.
Old Jun 25, 2014 | 12:33 PM
BAMini's Avatar
BAMini
How do you know it will decrease the handling of the car? No one even knows the rates.
PM'd you.
Old Jun 25, 2014 | 01:44 PM
Variance Doc
PM'd you.
So, let's think about this. Let's say you get the springs for a car with a sunroof and put them on car without. There is about 60+ lbs. due to the sunroof, which yields a higher center of gravity. My guess (based on my engineering background and racing experience) is the spring rate is higher for the sunroof car (as you pointed out - not a lot of info available about the rates). BMW knows this, hence the different part numbers.
So now, you probably have a car and spring combo that is not within it's natural frequency. The suspension is a system of the car, springs, dampeners, sway bars AND the environment in which the car is driven. Optimally, they should all be in sync for the best handleing. Anything outside of this, leads to suboptimal or worse handleing.
Old Jun 25, 2014 | 01:52 PM
BAMini's Avatar
BAMini
So you're telling me you would be able to feel the difference between the springs that went on a sunroof car and a non-sunroof car? Remember that even with +- 60lbs, the springs are NOT even 60lbs different by spring rate.
And on top of that, youre saying that if you don't get the appropriate springs, the JCWs would make your car WORSE off than stock or sport suspension?
I wonder why Eibach, H&R, etc do not make spring rates for every option... HMMMMMM.
Old Jun 25, 2014 | 02:07 PM
Variance Doc
1) Yes, I can tell the difference, especially on a smooth track or autobahn, or rough undulating surfaces.
2) Yes, it can. That was the whole point of my above post. Optimal handling is a result of the system in balance.
3) Scale of economies. BMW can do it; H&R and Eibach cannot.
I'm out....
Old Jun 25, 2014 | 02:17 PM
BAMini's Avatar
BAMini
Wow, good luck with your build. I'm not sure why you're even buying JCW springs. You're buying them on the assumption that JCW tuned those spring to match your driving style and needs. You have NO idea what the spring rates are and are making pretty large claims as to their performance.
Facts are: they lower the car, they are stiffer than stock.
By these two facts alone, I know that they will make any mini handle better than stock.
Old Jun 25, 2014 | 04:17 PM
BAMini's Avatar
BAMini
Sold.
silence2-38554
Nov 12, 2015 09:39 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
