Drag Racing 1/8 and 1/4 Mile MINI Runs
Where do you shift your R56?
Old Jun 6, 2014 | 06:15 AM
TEEZY's Avatar
TEEZY
What rpm do they like to be shifted at when racing?
Old Jun 6, 2014 | 06:48 AM
Fly'n Brick's Avatar
Fly'n Brick
Most shift at the top of the torque curve. The ones that don't never seem to keep up.
Old Jun 9, 2014 | 07:37 PM
Btwyx's Avatar
Btwyx
I don't drag race, but I am trying to go quick. It depends on the R56 and the gear. The theoretical way to do it is with a torque curve and you have to work out when the added gearing of changing up is less of a disadvantage than falling off the other end of the torque curve.
I have a spreadsheet to do that, and there's also an iPhone ap for it.
In a Cooper, its always advantagous to change up at red line.
In an 08 Cooper-S, red line from first and second, and slightly under redline for the higher gears.
In a 2012 JCW, its red line from first and slightly less with each gear, but the time you change up from 4th its 5900.
Old Jun 10, 2014 | 06:49 AM
TEEZY's Avatar
TEEZY
Great info!! thank you
Old Jun 19, 2014 | 05:53 AM
R53's Avatar
R53
Keep in mind if you change too early you will be out of the power band in the next gear. You have to find a compromise.
Old Jun 19, 2014 | 06:36 AM
dongood's Avatar
dongood
On my stock 2006 R53 I would normally shift at around 5500 RPM, this would leave me at about 4500 for the next gear.
If I shifted closer to red line then the next gear would begin around 5500, and the butt-dyno felt like there was less pull starting a gear that high.
So far my R59 feels about the same, but to be honest I haven't pushed this car as hard as the R53.
Each car is different, a little experimentation is needed to figure out what works best for your car.
chandler_vt
Apr 29, 2017 08:08 AM
cb_smalls
Aug 31, 2015 06:13 AM
Aug 19, 2015 12:51 PM
Mini-Hype
Aug 17, 2015 06:32 AM
