How to take off coolant water pipe
Old Jun 4, 2014 | 04:11 PM
AbsoluteAuto's Avatar
AbsoluteAuto
Hi
Just had the engine rebuild done, and discovered a small leak on the water pump to thermostat coolant pipe
question is how do i take the pipe off to inspect/replace??tried pulling very hard but did not work
the part is this http://mini.sewellparts.com/oem-cata...SLCI-2012.html
Old Jun 4, 2014 | 05:45 PM
Systemlord's Avatar
Systemlord
Originally Posted by AbsoluteAuto
Hi
If it wasn't leaking before your rebuild you should return it to them and see if they will fix it. I think you'll have to remove the water pump and thermostat housing, not 100% sure.
Old Jun 5, 2014 | 01:59 AM
AbsoluteAuto
I did the rebuild myself with the Bentley service manual, it states how to take off the water pump and thermostat but not how to take off this particular pipe
Old Jun 5, 2014 | 12:03 PM
afadeev's Avatar
afadeev
At what end does it leak?
There is a clip on the back end of the pipe on the thermostat end. Unclip it, remove the thermostat (requires removal of a bunch of coolant hoses as well as freeing one end of the plastic pipe), then pull out the pipe off the water pump. It's wedged in there tight, but will come out. Replace the gaskets before reinstalling.
Clearance are tight with the engine in place, but once the thermostat comes out you should also replace it as a preventative measure. Hopefully it leaked on the thermostat end, so you can leave the water pump side alone.
a
shorenetworks
Nov 4, 2019 06:18 PM
KinetechMW
Jan 22, 2016 09:04 AM
sempaipaul
Oct 26, 2015 05:56 PM
