R50/53 Flat tire monitoring system???
Old Jun 18, 2004 | 12:18 PM
Nick_T.'s Avatar
Nick_T.
After changing tire pressure it is necessary to re-initialize the flat tire monitoring system.
The Owner's Manual lists three steps:
1) Start the engine, but do not start driving.
2) Press the button (forward of the e-brake) long enough for the indicator lamp to light up for a few seconds.
3) Drive off.
Then there is a comment:
It takes a few minutes before the Flat Tire Monitor can detect a flat tire and issue an alert.
Does anyone know how long (or far) the car must be driven before the system has re-calibrated itself? Am I the only MINI owner that cares about picky stuff such as this? Am I being overly ****? Am I asking too many questions?
Old Jun 18, 2004 | 01:55 PM
JuanPacoLopez's Avatar
JuanPacoLopez
In my experience it takes about 20-30 seconds for the flat monitor to reset...
Usually I do it driving away from the air pump, by the time I'm out at the street it's done blinking
Old Jun 18, 2004 | 02:37 PM
lotsie's Avatar
lotsie
On a thread called tire pressure I asked if you had to reset after adding or taking out air and it would appear not
Old Jun 18, 2004 | 04:46 PM
OctaneGuy's Avatar
OctaneGuy
Don't know if this is helpful or not, but I got new tires yesterday. I drove for atleast 35 miles before I noticed the flat tire indicator flashing on my Tach. I held the button down while driving--didn't bother to read the manual. After about 20 seconds, the flashing stopped and disappeared.
Guess I'll reset it again since I'm home now. LOL. It's funny though, I don't think the flat tire indicator was flashing for those 35 miles cause I'm sure I would have seen it!
3) Drive off.
Old Jun 18, 2004 | 06:09 PM
Nick_T.'s Avatar
Nick_T.
I've done it three times - once after mounting the new wheels, and twice since after changing the pressures - and it's worked differently for me.
Each time I've waited until I got the warning and then I followed the instructions - start engine, hold button until the light remains on steady, drive off. I've driven as little as 10 miles and as much as 38 miles, and each time the light remains steady on until I switch off the engine - then on restart the light goes off as it should.
Old Jun 20, 2004 | 05:09 AM
BuckeyeMCS's Avatar
BuckeyeMCS
I just destroyed a runflat because my light never came on
Old Jun 20, 2004 | 05:55 AM
greatgro's Avatar
greatgro
Hmmm...You should definitely reset it after adjusting the air pressure in any way. Otherwise the monitoring won't be accurate.
Old Jun 21, 2004 | 12:40 AM
pocketrocketowner's Avatar
pocketrocketowner
I don't know about anybody else but I change tires CONSTANTLY (whe the sucker is running anyways) and I have never, ever done anything other than ignore the light for anywhere from a few seconds to a couple of minutes and it goes off. So far, it hasn't caused any flats......
woodstudio
Mar 15, 2020 08:28 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
ltjpunk7
Sep 6, 2015 07:32 AM
romansmini
Aug 25, 2015 11:57 AM
kyungmanpark
Aug 23, 2015 07:26 PM
