R50/53 Hatch won't open R53
Old May 29, 2014 | 07:07 AM
Blayne's Avatar
Blayne
I push the rubber button and it won't open. Once in a blue moon it opens but most of the time I have to pull the "rip chord". I read something once about this being a problem but I can't find it now. Is there a fix for this?
Old May 29, 2014 | 07:43 AM
Jones424's Avatar
Jones424
do you hear the click like it tries?
if not i had to replace my hatch actuator mounted on the body. Very simple to change.
Old May 29, 2014 | 07:47 AM
Saltysalt's Avatar
Saltysalt
they are also prone to rusting out, see if the light terminals are still looking good
Old May 29, 2014 | 09:29 AM
minsanity's Avatar
minsanity
This DIY should help you:
https://www.northamericanmotoring.co...html?styleid=7
Old May 29, 2014 | 12:02 PM
Looks at the handle microswitch or an lock mechanism itself. Water and corrosion can get in there past the gasket. Water / salt also goes up under the rear lights lens, then into the grip handle.
rikaro
Aug 7, 2021 02:33 PM
AoxoMoxoA
Aug 21, 2015 09:15 AM
coachvminis
Aug 17, 2015 01:42 PM
