Which size?
Old Jun 15, 2004 | 11:57 PM
miniotto's Avatar
miniotto
Which size?
I am trying to decide whether to get 215/45/17 or 215/40/17 on stock s lites on a cooper. I haven't lowered it yet but was just wondering if there was a big difference in size or rubbing anywhere or are the 40/17's to wide for the rims?
Old Jun 16, 2004 | 12:14 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Either size will work OK
The stock S-lytes are 17x7" and if you don't lower the MCS then you will have plenty of room for now with either of these two tire sizes.
The problem arrises as you lower the MINI the set of springs you choose could result in some rubbing if the tire shoulder is rather broad and square as is the case with H-sport springs and Yokohama ES100 215/45-17 tires which I have and they rub in the rear wheel wells with aftermarket 17x7" rims with 42mm offset.
The 215/40-17 would decrease the chance for any rubbing even with lowering springs added but the tire load rating for that size is below the load rating for the stock sized 205/45-17 tires. So don't put too many people and their luggage in a MINI if you have those 40 series tires. Neither tire is too wide for the stock rims.
Doc Pain
Oct 28, 2015 07:09 PM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
WhinyR53
Sep 30, 2015 07:36 AM
BossyR56
Sep 28, 2015 11:33 AM
mini_mike237
Sep 25, 2015 12:45 PM
