R50/53 R111 Black Star Bullet Rims on 2006 R50
Old May 14, 2014 | 07:41 AM
tpnass1's Avatar
tpnass1
I am going to need new tires soon on my 2006 R50 and I am also looking to upgrade the wheels (from 15" to 16" or 17") at the same time. I came across, R111 Black Star Bullet Rim for a good price and I am wondering if they can be mounted on my Mini???
Also, if yes I see the OEM size tire is 205/45/R17, what is a good tire for NE Florida weather to mount with it?
Old May 14, 2014 | 07:48 AM
Yes, they will fit, unless you have some aftermarket big brake kit. Very nice looking wheel and looks good on the Gen 1 MINIs.
R111 Black Star Bullet Wheel 17" (4x100) Black Turned Part # 36116784124
http://www.ecstuning.com/Search/SiteSearch/36116784124/
Here are some R111 shots on some Gen 2 MINIs.
https://www.northamericanmotoring.co...dy-kit-30.html
I am sure some guys will chime in on installer in FL. Good luck.
Old May 14, 2014 | 08:03 AM
tpnass1's Avatar
tpnass1
Thank you!
Everything on my Mini is currently stock... suspension, tires, wheel, etc... Is anything "special" required to install (i.e. sensors)???
Old May 14, 2014 | 08:04 AM
You should be good , TPMS for your MINI reads off the ABS sensor , so no wheel mounted TPMS sensor.
Thanks.
Old May 14, 2014 | 08:14 AM
tpnass1's Avatar
tpnass1
Any thoughts or input on how ride will be affected? I know the combination of tires and rims will weigh more going from 15x5.5 to 17x7 thus decreasing the cars "playfulness" (acceleration) but I am curious of how much. I believe these rims are on the lighter side of 17" alloys OEM's so maybe it wont be that noticeable???
MPG???
Old May 14, 2014 | 08:19 AM
Wheel feel will be tighter, response wise. When I went from 15" R93 rockets to 17" R91s bullets as they are called. They are heavier then 15" MINI wheels. So for mpg varies, seen a very slight drop, not much. But this was on a R52 Cooper Convertible ( Non S ).
Colt45Magnus
Sep 7, 2015 10:47 PM
polotska
Aug 21, 2015 11:55 AM
Powershift
Aug 16, 2015 05:14 PM
Emnotek
Aug 13, 2015 05:47 PM
rphox2003
Aug 5, 2015 11:34 AM
