R56 Removing Door Entry Strips
Old May 11, 2014 | 04:37 AM
nashdm2's Avatar
nashdm2
Hi, I have these fitted to my 2010 R57, they are the JCW ones and I think they were fitted from new. I want to fit a new set of illuminated ones to the car, so, how would you suggest I remove the old ones. Would you suggest I slowly lift them with a plastic tool of some sort, or, use dental floss underneath first?
How would you then clean the mess underneath with the glue/tape etc, what would be the best "stuff" to use to easily clean the mess off? Thanks, Dave
Old May 11, 2014 | 05:05 AM
cerenkov's Avatar
cerenkov
Just rip them off. I used a plastic spatula. They are nearly impossible to save. New ones cost about $50 each if the illuminated one don't work out..
Try "goof off" for the tape mess underneath. What ever you use, first try it in a spot that will be covered by the new strip, in case it damages the paint/finish.
Old May 11, 2014 | 05:06 AM
danjreed's Avatar
danjreed
Simply, lift, grab and peel.
Don't expect to use it again once it comes off,
As for the cleanup, WD-40, followed with a little goof off works.
Old May 11, 2014 | 02:30 PM
Ive's Mini's Avatar
Ive's Mini
I just removed both of mine after the adhesive allowed the corner to lift ann d get kabashed by the door. I used a heat gun and got them off without damaging them further. I straightened them to the best of my ability and put them back on with 3m molding double sided tape.
greekzilla
Aug 23, 2015 03:44 PM
Chippawaguy
Aug 18, 2015 11:17 AM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
ludedude
Aug 10, 2015 07:16 PM
