R50/53 Power Steering Return hose
Old May 11, 2014 | 12:12 AM
tsmsoccer's Avatar
tsmsoccer
My Steering pump hose the one from the Steering pump back to the reservoir is leaking.
I have found a number of sellers in the US but as I live in Australia with Right hand Drive can anyone tell be if the US part will fit.
I am assuming the Steering Rack will be different between left and right hand drive models so my concern is the hose will be different as well
thanks in advance
Charlie
Old May 11, 2014 | 12:58 AM
minsanity's Avatar
minsanity
Input your VIN over at RealOEM.com & compare w/ the LHD US hose repair kit PN:Mfg#: 32416781744KT
Return pipe only:32416781744
http://www.ecstuning.com/News/MINI_R...006_2007_2008/
Old May 11, 2014 | 04:39 AM
tsmsoccer's Avatar
tsmsoccer
Thanks for the reply when I checked Rel OEM my part no is 3241678145 the last digit is different
Old May 11, 2014 | 05:04 AM
minsanity's Avatar
minsanity
Can't you source em from local dealerships? Shouldn't be much pricier than US vendors. Verify w/ UK vendors. Consult w/ the guys over at minitorque.
Old May 12, 2014 | 02:09 AM
tsmsoccer's Avatar
tsmsoccer
You would be surprised at the price difference from the us$100 from a Mini dealer here in Australia $280 plus delivery
Old May 12, 2014 | 03:12 AM
minsanity's Avatar
minsanity
Wow, must be cheaper to source them from Hong Kong or Singapore if the UK should be too far from you. They all have RHD.
Old May 12, 2014 | 12:34 PM
Da_Ghost's Avatar
Da_Ghost
Mine was leaking too and I just cut the oem clamp and installed a hose clamp, fine since then.
Old May 25, 2014 | 09:34 AM
neuralstatic's Avatar
neuralstatic
i did the same diy repair on this -- it went well, though a little crowded under there.
unfortunately, i had already picked up a clicking on extreme turns.:/
Etrain
16
Aug 5, 2024 04:37 AM
Manny_cooper
Sep 10, 2015 11:09 AM
kellymac
Aug 30, 2015 10:11 PM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
