Drivetrain Correct torque for spark plug install on N18?
Old May 7, 2014 | 04:49 PM
pidge1114's Avatar
pidge1114
I think I read it's 20/lb of torque when tightening spark plugs. Anyone weigh in?
Old May 7, 2014 | 05:03 PM
danjreed's Avatar
danjreed
16 ft lbs- 23Nm.. Cold engine, no anti seize.
Old May 7, 2014 | 06:14 PM
pidge1114's Avatar
pidge1114
Thank you!
Old May 8, 2014 | 04:49 PM
pidge1114's Avatar
pidge1114
So now in another thread I've read all over the place...14.5, 16, 17....
Does it matter which brand of spark plug? I don't want to over/under tighten.
Old May 8, 2014 | 04:50 PM
danjreed's Avatar
danjreed
Originally Posted by pidge1114
So now in another thread I've read all over the place...14.5, 16, 17.... Does it matter which brand of spark plug? I don't want to over/under tighten.
1.5 ft lbs is not critical... Chances are your wrench unless recently calibrated is off by at least that much.
Old May 8, 2014 | 04:56 PM
pidge1114's Avatar
pidge1114
So I'll split it down the middle, right where you said...at 16.
Old May 8, 2014 | 09:21 PM
bmwr606's Avatar
bmwr606
and if you are using a 1/2 drive 100 foot/pound torque wrench you could be 20-25% off because of the low torque you are trying to set!
torque wrenches are very inaccurrate below about 25% of full scale and above about 85% full scale
in aviation we try to stay between 30-75% of full scale ... so i have a set of torque wrenches and they all get calibrated every year
my set covers torques from 5 inch/oz to 800 foot/pounds ... then come the torque multipliers for the really big stuff!
Old May 14, 2014 | 08:57 AM
Mcameron's Avatar
Mcameron
apply antiseize....tighten until snug +1/4 turn........never given me any issues.
unless youve never turned a wrench in your life, i see little value in torquing plugs to a given spec.
Old May 14, 2014 | 10:33 AM
v10climber's Avatar
v10climber
Most people that turn wrenches for a living understand that there is a very good reason for torque specs. They also love it when people don't use torque wrenches since they get to make money on fixing blown out spark plugs or stripped spark plug threads. On an aluminum head you bet I'd be using a torque wrench.
Old May 19, 2014 | 01:02 PM
rckrzy1's Avatar
rckrzy1
YEP
And nothing like that sick feeling when tightening something down when it all of a sudden get looser . followed by
Old May 19, 2014 | 01:11 PM
pidge1114's Avatar
pidge1114
Actually that is exactly the wrench I have...a 1/2 inch 100ft/lb with a 3/8 adapter. Are you saying that setting it to 16 won't really be 16?
Old May 19, 2014 | 03:26 PM
v10climber's Avatar
v10climber
Correct. For 16 ftlb you're looking at something closer to a in/lb torque wrench
Sent from my Nexus 10 using NAMotoring
blackie
Jan 18, 2017 09:56 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
blackie
Aug 23, 2015 08:44 PM
yashmack
Aug 15, 2015 10:16 AM
flredmini
Aug 12, 2015 06:35 PM
