R50/53 Noise when turning wheel
Old May 1, 2014 | 11:48 AM
johnny63's Avatar
johnny63
i have this exact problem, any ideas?
Old May 4, 2014 | 07:18 AM
fastzombie's Avatar
fastzombie
I had a similar groan coming from my 2004 Mini Cooper S. It turned out to be mechanical in nature related to the steering column lower U-Joint. I had the steering shaft replaced due to age related damage to the lower U-Joint and the groaning is now gone.
Old May 4, 2014 | 09:19 AM
scoopy's Avatar
scoopy
do you have the part number of the lower u-joint? thanks
Old May 4, 2014 | 06:49 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Mine is making the same noise.
Old May 4, 2014 | 07:53 PM
c0op3r's Avatar
c0op3r
Look at the Front Shock Mounts.
Open the hood, and look in the hole in the shock mount, have someone turn the wheel (with the car off) while you look at it.
If its ripped you will see it move and see the tare, replace the mounts.
Old May 4, 2014 | 08:38 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I have new mounts.
Old May 5, 2014 | 01:56 PM
fastzombie's Avatar
fastzombie
The part was : 32-30-6-763-722-M26
The lower steering column and U-Joint. I know you can find it from a number of places. I think it costs around $165 to $200.
I would really check the strut mounts in the front as well before changing out the steering column with the lower u-joint. I know you can get a groan from bad strut mounts too. My strut mounts were brand new with less than 100 miles when we narrowed it down to the steering column and lower U-joint.
Old May 5, 2014 | 03:41 PM
cristo's Avatar
cristo
Alliance Member
I had a torn upper strut mount, which was silent.
The new replacement mount gave a noise like that, only not quite as bad,
mostly in cold weather, and mostly near the extremes of wheel turn.
It's been gradually diminishing over the last couple years since it was put in.
A spray of silicone lubricant helped.
Old May 5, 2014 | 04:03 PM
SSSSSSSS's Avatar
SSSSSSSS
Coordinator :: M2C2
My R53 did the same thing and was solved by lubing the u-joints and slip joint with Wurth spray lubricant.
Old May 5, 2014 | 04:57 PM
c0op3r's Avatar
c0op3r
I have a Steering Column u joint if some one wants it for 65.oo
rikaro
Aug 7, 2021 02:33 PM
maestro39
Oct 27, 2015 02:38 PM
damncajun
Aug 17, 2015 08:25 PM
yashmack
Aug 15, 2015 03:11 PM
nismo4life
Aug 5, 2015 08:31 AM
