2008 MCS with suspension issue
Old Apr 26, 2014 | 02:37 PM
Bonestock's Avatar
Bonestock
Hello there is have been trying to identify an issue I'm having with my 08 MCS with about 45k. Been having excess road noise through steering wheel and overall ride. Checked most everything I can think of. There is no slop in steering and when I got the car off the ground I noticed my torque arm bushing looked a little odd. Is the bushing supposed to have a snug fit to housing on the arm? I will attach some pics to see if I can help illustrate my question. Any help on this would be great or a pic of a norm bushing that I could compare mine too
Old Apr 27, 2014 | 06:30 AM
mbwicz's Avatar
mbwicz
My first instinct is to look at the tires. If the torque arm bushing was funky, I would expect that the noise would change with engine rpm.
Any mods?
Have fun,
Mike
Old Apr 27, 2014 | 12:01 PM
Bonestock's Avatar
Bonestock
No suspension mods as of yet!
there are no suspension mods as of yet but i took some shots of the bushing and it looks kinda worn out but then again i have nothing to compare it too. :-(
Attached Thumbnails 2008 MCS with suspension issue-unnamed1_zps99e08e67.jpg   2008 MCS with suspension issue-unnamed2_zpsa37f818e.jpg   2008 MCS with suspension issue-unnamed4_zpsd7d8120a.jpg
Old May 5, 2014 | 03:11 AM
MattyChiliT's Avatar
MattyChiliT
I believe that bushing looks normal, I remember it not being solid so those gaps you see could be correct. did it look torn at all?
Old May 12, 2014 | 08:36 AM
afadeev's Avatar
afadeev
At 45K miles you should be nearing the end of the lifespan of stock tires. Are they near the wear bars yet?
If yes, all tires get noisier and harder as the amount of thread decreases.
If the tires are new, what new tires did you install?
Does your noise change wary with speed?
Does it get louder during turns (equal amount left vs. right)?
HTH,
a
P.S.: There is nothing obviously wrong with your engine mount/stabilizer bushing. At 45K miles, you should not expect significant suspension wear yet, unless you hit some major pot holes lately, it which case anything is possible.
W0TM8
Dec 19, 2019 07:50 AM
maestro39
Oct 27, 2015 02:38 PM
Minibeagle
Aug 13, 2015 10:00 AM
nomar116
Aug 10, 2015 11:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
