Squeaking brakes on a new MC
Old Jun 12, 2004 | 02:11 PM
Panganiban's Avatar
Panganiban
Hey guys...Just wondering if there is something wrong with my brakes already. Got the new Mini about three weeks ago and from time to time I hear squeaking. Just wondering if this normal or if it is something I should call the dealer about? Happens maybe once every two to three days. Any advice would be greatly appreciated. Thanks!
Old Jun 12, 2004 | 03:47 PM
2minis's Avatar
2minis
Probably normal. Disc brakes will squeal at times. If it isn't pulling or is not stopping as it should get it checked. The dust you see on your wheel is from the brake pads and the dust itself is sometimes the cause of the squeal.
Old Jun 12, 2004 | 03:50 PM
Panganiban's Avatar
Panganiban
Alright...I guess I won't let it bug me for now. I do see brake dust on the wheels, so that probably is the cause, hopefully.
Old Jun 12, 2004 | 05:03 PM
kenchan's Avatar
kenchan
My brakes tends to squeak after there is some oxidation on the rotor
after a car wash or sitting in the rain. It will squeak at less than 5mph
to a stop. wat I usually do is spray some RC car motor spray onto
the pad to clean it off. For some reason, it appears it is always the outer
pad that's making the squeak.
A drop of WD40 on a cold rotor will also work too, but I would recommend
cleaning the pad with a blast of the RC car motor spray first as you want
to try to stay away from excessive oils on the rotor or pads.
Old Jun 12, 2004 | 05:19 PM
Panganiban's Avatar
Panganiban
Yeah, mine tend to squeak when I'm parking so its also happening below 5mph. Anyway, thank goodness its not really a problem, I guess. Where can I pick up that RC motor car spray? A hobby shop or something???
Old Jun 12, 2004 | 05:57 PM
kenchan's Avatar
kenchan
Yep, hobby shop should have them. :smile: The nitro cleaner will also work.
Old Jun 14, 2004 | 01:07 PM
Alex@tirerack's Avatar
Alex@tirerack
or traditional brake cleaner - watch out for plastic though! Brake harder! it will help!
Alex
Old Jun 16, 2004 | 11:34 AM
kenchan's Avatar
kenchan
Is the brake cleaner and RC motor spray the same thing? It smells very
similar... I haven't tasted it yet.
torpeau
Sep 10, 2015 07:59 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
Suspension Products
Sep 3, 2015 09:41 AM
