R56 Trunk grab handle switch dead
Old Apr 22, 2014 | 07:15 AM
richardsperry's Avatar
richardsperry
Ok, first real problem...
The trunk will not open if I try to use the grab handle.
Yes, I have comfort access, and the doors all work. The key fob will pop the trunk, so I assume that the grab handle switch is bad.
My question is, is there a cheaper fix than buying a new $210 grab handle?
I removed the handle and can't figure out how to open it up without destroying it..
Rich
Old Apr 22, 2014 | 10:45 AM
oldbrokenwind's Avatar
oldbrokenwind
In the middle of a major repair, and I can't open my hatchback to get stuff out. I'm guessing it's because the battery is disconnected, and the mechanism is electric, not mechanical. You might want to check for a blown fuse or disconnected / broken wire.
Old Apr 22, 2014 | 11:35 AM
Namotuman's Avatar
Namotuman
I had the same problem...luckily my warranty was still active and when I took my mini in for service, I mentioned it to the rep and it was replaced........
Old Apr 22, 2014 | 12:24 PM
holkki's Avatar
holkki
Common problem!You must little bit destroying it,just twist the screwdriver or something a suitable tool between the body and backcover.Mine cover came off really easily and to reveal the micro-switch which was not fit properly.A small drop of glue to the frame of switch and gasketglue keeps cover back to handleframe. It`s very easy job! In Finland is really weird pricing, unpainted is expensive than chrome version!And carbon fiber is almost three times more expensive...
Old Apr 22, 2014 | 01:47 PM
Systemlord's Avatar
Systemlord
You'll need a T25 torx screwdriver to remove the entire handle from the hatch, it's easier to remove your license plate first.
carid
Dec 28, 2025 04:11 AM
BucksCountyR57
R57 :: Cabrio Talk (2009+)
Sep 21, 2015 05:42 AM
David Eric Rosenberg
Sep 10, 2015 12:34 PM
CSC_R53
Sep 9, 2015 03:12 AM
