R50/53 Heater core help!
Old Apr 14, 2014 | 08:08 PM
nap51dcrow's Avatar
nap51dcrow
Heater core help!
Hello,
I have been fixing minor issues with my 03 MCS and noticed I was leaking coolant from the heater core feed line at the firewall so I replaced the line only to find that the aluminium line that is inside the car directly attached to the heater core is damaged.
I have new parts coming to fix everything, but in the mean time, I cant just let my car sit broken, so does anyone know what would be the best way to circumnavigate the damaged heater core? I have 2 options and I am not sure which is the best.
1- Cap the feed and return lines just before the firewall and be done with it
2- Make a "U" section of hose and connect it between the feed and return lines to simulate the flow through the heater core.
I dont want to damage the cooling system or anything, and I just dont know the best way to temporarily fix my car until I have time to replace everything.
I appreciate any thoughts or suggestions.
-Kevin
Old Apr 16, 2014 | 07:45 AM
I think the U section of the same diameter would be the best in the short run.
Here is the parts and a link to :
https://www.northamericanmotoring.co...-in-cabin.html
Thanks and hope you can get things fixed.
Old Apr 16, 2014 | 10:56 AM
nap51dcrow's Avatar
nap51dcrow
Thanks for the help.
I dont suppose you know if I need to remove part #4 on your diagram when I get ready to change the metal lines? I havent found much info on changing them.
PsychoRallye
21
Feb 17, 2019 06:08 AM
asmasm
Aug 18, 2016 09:34 PM
Helix13mini
Jul 27, 2016 06:29 PM
silence2-38554
Sep 28, 2015 12:19 PM
Redhotz
R55 :: Clubman Talk (2008+)
Sep 22, 2015 09:41 PM
