R56 Mini Cooper S Headlight Washer Jets not working....
Old Apr 5, 2014 | 07:22 PM
fotomatt1's Avatar
fotomatt1
I've had my new 2013 Mini Cooper S for a month. it's equipped with Xenon headlamps with headlamp washer jets. For some reason I suspected that they weren't working and today I asked my wife to watch while I activated the windshield washer jets, which as far as I know is also supposed to activate the headlamp washers. Nothing happened. I'll take it to the dealer and have them repaired, but just curious if there is something else I should be doing in order to activate the headlamp washers? Any advice? Thanks in advance...
Old Apr 5, 2014 | 09:31 PM
unibus_driver's Avatar
unibus_driver
Did you have the lights turned on when you were doing this?
Owner's manual says "When the vehicle lighting system is switched on,
the headlamps are cleaned at regular and appropriate intervals."
Old Apr 5, 2014 | 09:57 PM
vetsvette's Avatar
vetsvette
Moderator
Lights have gotta be on.
Old Apr 5, 2014 | 10:00 PM
Tonyruggles's Avatar
Tonyruggles
They have to be hooked up also. I have the xenon headlights also but the washer jets weren't bought as an option by the first owner so they weren't hooked up.
Old Apr 6, 2014 | 04:47 AM
fotomatt1's Avatar
fotomatt1
Hmmm....I thought that if they were there, they're enabled? Does that mean if they're not enabled the tubing and wiring for the jets isn't there?
Old Apr 6, 2014 | 05:15 AM
doseddies's Avatar
doseddies
Also it's like every fifth time you squirt them window washers. Not each time. But yes the lights have to be on.
Old May 28, 2014 | 03:37 PM
Coogz's Avatar
Coogz
I would like to know this as well...Upon realizing what that chrome half circle was inside the headlamp trim of my Xenon's, I got real excited, only to realize there is no tubing connected to the nozzles. What exactly would I need to enable them? The whole pump, or reservoir? Or just tubing? I drive a 2011 MCS.
Old May 29, 2014 | 10:02 AM
Tonyruggles
Somebody might correct if I'm wrong but I'm sure you will have to have programing donefor control of the jets. Then also of course plumbing to the jets themselves.
Old Jun 1, 2014 | 09:32 PM
Womanual's Avatar
Womanual
I think the washers come with the cold weather package but totally sure. I got Xenons but not that package. Didn't even know what those silver things were till someone else pointed it out to me. You can easily look to see if they are connected to anything. It was obvious mine weren't.
Old Jan 27, 2015 | 05:44 AM
2014-JCW's Avatar
2014-JCW
Ok, I know this is an older post but I didn't know if I should create another duplicate post.
My wife just bought a new 2015 Cooper S roadster. We wanted the Xenon headlights because it was bright and had headlight washer jets. I have a 2014 Cooper Countryman JCW with Xenon light and headlight washer jets. The question is this both of our Mini's have the cold weather package and xenon headlights. My MIni has the headlight washer jet, but my wife's Mini does not. Looking at Mini USA website under 2015 Mini Cooper S roadster features it says cold weather package comes with headlight washer jets if equiped with Xenon headlights. However, her Roadster S does not have the headlight washer jets. I know this because there is no washer jets under those chrome covers. There is just a spring holding the little chrome cover to the headlight trim ring.
She is a little disappointed because she feels she paid for something that she didn't get. If the Mini USA website didn't list this as one of the features of cold weather package and xenon headlights she wouldn't care too much.
Thanks all, any input would be great.
Old Feb 2, 2015 | 12:50 AM
a2oc's Avatar
a2oc
as long as u got the factory installed xenons (35w), u will have the headlamp washer as its a legal requirement in europe.
Old Feb 2, 2015 | 06:12 AM
u238's Avatar
u238
Nope. The washer might be installed in the headlight, but none of the piping is there.
Old Feb 2, 2015 | 06:31 AM
spiney's Avatar
spiney
Last time I looked at the configurator for the Roadster the washers were an option on the Xenons. They used to be standard but that seemed to have changed.
Old Feb 2, 2015 | 09:44 AM
Slave to Felines's Avatar
Slave to Felines
Sounds like it's dealer time.
Old Feb 2, 2015 | 09:46 AM
2014-JCW's Avatar
2014-JCW
I thought that too. But when I look at mini USA website the headlight washer jet is listed as one of the features of my wife's roadsters (if the vehicle has cold weather package and xenon lights.) I'm going to ask the salesperson. Hopefully he will have something to back up why my wife's roadster s doesn't have those headlight washer jets.
Old Feb 2, 2015 | 12:28 PM
TheBigNewt's Avatar
TheBigNewt
Has anyone ever seen those things in action? I can't imagine they do much good just spraying water without something wiping the headlight glass itself.
Old Feb 2, 2015 | 12:52 PM
JR2012IBB's Avatar
JR2012IBB
I had them on my Audi and disabled them. They are marginal in terms of effectiveness and the amount of fluid they blast out runs the fluid down pretty quickly. I prefer to keep the sprays up on the windshield where it actually does some good.
Old Feb 2, 2015 | 12:54 PM
spiney's Avatar
spiney
They spray a lot of water at a good pressure and volume. My headlights have always been clean. They also empty the tank in double quick time.
Old Feb 2, 2015 | 01:09 PM
rckrzy1's Avatar
rckrzy1
I must be doing something wrong, I just keep my car washed and never have needed to clean my headlights.
Old Feb 2, 2015 | 03:21 PM
TheBigNewt's Avatar
TheBigNewt
What he said. This is a Mini, not a jacked up F-150.
Old Feb 2, 2015 | 05:58 PM
AZdsrt's Avatar
AZdsrt
Here ya go -
Old Jul 24, 2016 | 09:37 AM
ssashton's Avatar
ssashton
Hi Guys,
On my R53 the headlight washer on both sides pop out as they should, but only one side (nearest the fill bottle) sprays well. The other side just makes a dribble.
Any tips on getting this working?
I guess it's clogged but repeated use doesn't seem to clear it. It seems like the kind of thing that should have a service mode to clear the spray by prolonged pumping.
Old Jul 27, 2016 | 05:43 PM
aabcds's Avatar
aabcds
Originally Posted by ssashton
Hi Guys,
Maybe a tube is loose or there is a leak?
Old Jul 28, 2016 | 12:07 PM
cargusjoh's Avatar
cargusjoh
So, I also have Winter package, Xenon, the sprayer chrome flap, but no working sprayer. Is there anything I can do to make them work short of doing to the dealer? Thanks!
Old Jul 28, 2016 | 12:10 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
Wow most threads are about disabling them they make a mess
