Suspension wheel rub concerns
Old Mar 31, 2014 | 04:37 AM
welcha13's Avatar
welcha13
wheel rub concerns
Hello all! Been a while since I posted.
I've got an '06 MCS with (what I believe)* Hotchkis H-Sport lowering springs.
I just bought new tires for the rear and decided to change them from 205/45R17 to 205/50R17. I just like the look better and figured it would gain me a tiny bit more clearance off the ground. Well since the change I've noticed the rear wheels are rubbing inside the wheel well on every bump. Never noticed any rubbing before and now I've gotten 1cm more tire and now it's rubbing. I guess I was REALLY close before.
Do you think it's something I should be concerned about? I don't want the trim cracking off. I'll try to get photos this afternoon.
It IS possible for me to adjust the camber and probably avoid rubbing but I'd really like to avoid the excess tire wear that comes along with that.
*Prev owner never told me what springs were installed but it's got H-Sport adj control arms so I figure the springs probably match.
Old Mar 31, 2014 | 05:23 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
The tire is probably rubbing on the inner fender liner close to the wheel arch trim eventually wearing a hole through it and then you wont hear rubbing. Rubbing will chafe against the outer corner of the tire making it look like you've been taking on/off ramps at max speeds....and I guess some moisture will be able to get up in there but should not cause any issues. I would not recommend a camber adjustment as a fix if this is a daily driver unless tires come cheap to you.
Old Apr 11, 2014 | 09:43 AM
welcha13's Avatar
welcha13
Thanks for the input. The noise actually did go away after a couple days. I now only hear it if one side is higher than the other (like going halfsies over a speed table).
Rennfahrer555
General Discussion
38
Nov 1, 2022 03:04 PM
devicemanager
Jun 17, 2016 06:18 PM
06R53
Aug 26, 2015 08:37 AM
3MCS1DJ
Aug 23, 2015 02:08 PM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
