R56 What is a good summer tire?
Old Mar 26, 2014 | 07:37 AM
DOtheDEW's Avatar
DOtheDEW
im looking to get some sticky summer tires for a 17in rim, what do you guys recommend? i went to my tire shop, he recommended conti extreme dws, anyone have these?
Old Mar 26, 2014 | 07:43 AM
Flyinace2000's Avatar
Flyinace2000
There is an entire section of this forum dedicated to Tires and Wheels. Lots of good info over there. I personally have Potenza Pole Positions on my Clubman S and am very happy with them.
Old Mar 26, 2014 | 07:52 AM
DOtheDEW's Avatar
DOtheDEW
haha completely forgot about that, thanks!
Old Mar 26, 2014 | 08:32 AM
go_mini's Avatar
go_mini
the continentals dws (dry,wet,snow) are all season and are very good tires for all season, I used to have them on my other mini. I'm also looking for summer tires now as well to replace the runflats, and I'm leaning toward the michelin pilot ss.
Old Mar 26, 2014 | 08:48 AM
jcauseyfd's Avatar
jcauseyfd
As noted, the Conti DWS are all season tires. The Conti DW is a summer tire. I'd recommend it over the DWS.
Old Mar 26, 2014 | 09:28 AM
rckrzy1's Avatar
rckrzy1
conti DW worked great on or as best it could be in ICE storms, twice drove 30 mile R/T's to airport in ICE conditions with no problems.
Better than my run flats but I can still spin the tires on launch. Also seem to be wearing fast.
Old Mar 26, 2014 | 09:33 AM
Z06_Pilot's Avatar
Z06_Pilot
Oh, Michelin Pilot Super Sports !
Simply awesome rubber....don't even think about taking them out in the snow, and be careful on dry pavement when it's below freezing temps. Definitely 2 season tires only
They heat up quick and maintain grip over a good amount of time....
Downside for all that adhesion? Only a 30k mile tread warranty.
BUT for 17" sizes they should not be too expensive.
Old Mar 26, 2014 | 10:44 AM
colinmini's Avatar
colinmini
Bridgestone Potenza RE-11A's if you are looking for one of the best summer tire out these. Tons of grip!
Old Mar 26, 2014 | 10:47 AM
rckrzy1's Avatar
rckrzy1
You guys and tread wear warranty crack me up.
If you can get 30k on any tire you don't
Warrant sport tires.
Make it fast or make it last. Can't have both
Old Mar 26, 2014 | 12:14 PM
ChaiLatte's Avatar
ChaiLatte
+1. Not to mention most summer tires don't even offer a tread-wear warranty. 30K for a summer tire as great as the PSS is incredible.
I just finished off a set of Hankook V12's. I got 10K out of them with spirited driving and one track day. I liked them more than I thought I would. Grip is still good even though I'm down to 1/32nds of tread and the ride was pretty quiet up until a couple thousand miles ago.
If you're considering the Conti DW's keep in mind that they have a very soft sidewall and a lot of people complain about the dull steering response. On the flip side the ride is supposedly smoother and quieter than many other summer tires.
EDIT: Also, keep in mind that if you up your tire size to 215/45/17 your choices will increase significantly. For example, Michelin Pilot Super Sports are excellent tires but are not available in 205/45/17's. Just something to keep in mind.
Old Mar 26, 2014 | 05:19 PM
DOtheDEW's Avatar
DOtheDEW
I meant the conti extreme dw's not dws haha
Old Mar 26, 2014 | 05:20 PM
DOtheDEW's Avatar
DOtheDEW
I was considering doing 215s but I'm afraid of rubbing since I'm lowered on nm springs
Old Mar 26, 2014 | 05:25 PM
richardsperry's Avatar
richardsperry
Another vote for the Michelin PSS (215-45-17)
Old Mar 26, 2014 | 05:26 PM
CFMINI's Avatar
CFMINI
Nitto NeoGen
Old Mar 26, 2014 | 05:29 PM
Z06_Pilot's Avatar
Z06_Pilot
100% correct my friend, and a great tip. There are 5 or 6 pages of choices at Discount Tire in the 215 size....
Old Mar 27, 2014 | 05:58 AM
yetti96's Avatar
yetti96
+1 for Mich PSS in 215/45-17 Wear them out in 20-25k miles and warranty the remainder.
Old Mar 27, 2014 | 06:38 AM
Z06_Pilot's Avatar
Z06_Pilot
You don't need both if you have a treadwear warranty. I have had 4 PSS tires replaced under the Michelin 30k warranty on my Z06.
I prefer to "make it fast, wear them out, and make the manufacturer replace them under warranty"
I love treadwear warranties on sport tires
Old Mar 27, 2014 | 06:58 AM
Subzero's Avatar
Subzero
I have Michelin Pilot Super Sports and love them, but.....
The 30k treadlife warranty will be a lifesaver, as mine are pretty worn out with less than 11k on them.
There's simply no way anyone will get anywhere close to 30k on these.
Discount Tire warranty minus MINI club discount FTW!
Old Mar 27, 2014 | 08:19 AM
Z06_Pilot's Avatar
Z06_Pilot
Yes, as someone else mentioned, if someone gets 30k miles on these tires and still have tread left, they might want to buy a cheaper tire, because that person is definitely using the car a a grocery getter and not much else
Old Mar 28, 2014 | 08:48 PM
Moreyel's Avatar
Moreyel
Hey ChaiLatte, Does upping the tire size present any potential rubbing problems?
Old Mar 28, 2014 | 11:12 PM
bmwr606's Avatar
bmwr606
+1
my independant tire store warrants the tires plus they beat every price i have seen, i got 4 x 225/50R18 PSS for $600 installed/balanced/out-the-door ... the next set will be even less due to the treadwear warranty!
Old Mar 31, 2014 | 06:37 AM
DOtheDEW's Avatar
DOtheDEW
from what my tire guy told the me, the conti extreme dw have a 40k mile tread warranty, these tires are about $60 less a tire than the michelin pilot super sports, are the michelin really worth that much extra? i was reading reviews and they were all saying the tread wore out way too fast, around 16k miles...
Old Mar 31, 2014 | 06:40 AM
DOtheDEW's Avatar
DOtheDEW
also does anyone have the bf goodrich g-force t/a kdw 2? ive heard some good things about them from my buddy with his subaru and to be honest the tread on them look awesome.
http://www.tirerack.com/tires/tires....ce+T%2FA+KDW+2
Old Mar 31, 2014 | 06:53 AM
cristo's Avatar
cristo
Alliance Member
The Conti extreme DW are more comfortable and longer lasting, and the Michelen PSS
have better performance. Both are very good tires. Choose accordingly.
Old Mar 31, 2014 | 07:48 AM
jcauseyfd's Avatar
jcauseyfd
You might want to have your tire guy check again. I don't think the DW comes with any tread life warranty. The DWS on the other hand, comes with a 50k mile tread life warranty.
