R57 Rear shelf removal. Can it be done? Anyone here do it?
I have a 2011 convertible. Does anyone know if the rear shelf can be removed and if so, how? I know the small leg on the driver's side presses in the switch that allows the convertible top to open but other than that, does the shelf serve any real purpose?
I would love to remove it so I can open up some more cargo space and allow stacking of cargo but I'm not sure if that shelf does anything else important or how I would remove it. As for the switch, a piece of duct tape would take care of that. Just need to make sure I don't put the top down when I have cargo stacked back there.
The rear shelf is easily removed. Release the luggage compartment Easy Load levers and lift up the back hinged portion of the roof, and you can see how to pull the shelf out.
The rear shelf doesn't serve any practical function when the roof is up. When the roof is down, it supports the folded roof which would otherwise sag into the luggage compartment, and the rear window can break (it has happened to someone in the UK).
Only thing I'm not seeing is how to unhook the metal crossbar that attaches it. It doesn't just pull out. Looks like something is holding it in place.
silence2-38554
Aug 29, 2015 08:10 AM
