R58 Fitting Aux gauges
Old Mar 24, 2014 | 03:38 PM
The Patagonian's Avatar
The Patagonian
Fitting Aux gauges
Planning to fit Prosport water temp & boost gauges next week and I'd be interested if anyone has already done this - I was looking for any tips you may have.
Boost looks like a straight forward fit but not sure where to break into the cooling system - kit hasn't arrived yet but I understand there is a joint under the header tank where you fit the sender?
Any suggestions for picking up power for the lighting?
Old Apr 5, 2014 | 04:45 PM
Tabintab's Avatar
Tabintab
Why? You do realize that modern cars remove stuff like that now & only tell you when somethings wrong?
Old Apr 7, 2014 | 01:09 PM
The Patagonian
Of course I realise the car will tell me if there's a problem. If I was worried about the health of the engine I'd go for an oil pressure setup instead.
I'm only interested in knowing when the engine is warm enough to start giving it some stick. The boost gauge is only for fun.
Old Apr 7, 2014 | 02:47 PM
Tabintab's Avatar
Tabintab
How about getting the Torque app for a mobile phone and buying a OBD / Bluetooth adaptor. https://play.google.com/store/apps/d...g.prowl.torque
Setup costs are minimal £15.00 & u can check for fault codes & reset them also. I have this app myself and a cheapo OBD / Bluetooth adaptor, its very good. And yes, it tells you when your temp reaches optimal for high speed fun.
Old Apr 7, 2014 | 09:46 PM
Melangell's Avatar
Melangell
Sigh....
Booster tap
Gauge mounts if you don't already have an idea...
Patagonian, I'm hoping that you are old school like me and just like a gauge. The kit has the wiring you will need. Good luck and Motor On, brother, from the colonies!
Old Apr 8, 2014 | 03:14 PM
The Patagonian
Thanks for suggestion Tabintab but it just wouldn't suit me, I know I would drive off with the phone in my pocket every time and as Melangell says you can't beat an old school gauge :-)
Gauges have been mounted and electrics sorted (on paper at least). In reality you don't need the constant 12v supply as stated in the instructions unless your gauges have a memory function (which mine don't) so gauge and lighting can both be run from any ignition controlled accessory.
W0TM8
Dec 19, 2019 07:50 AM
surfblue
Oct 24, 2018 01:20 AM
bjcarter2
Aug 31, 2015 04:03 PM
tylewis
Aug 18, 2015 06:53 AM
dchang0
Aug 10, 2015 03:37 PM
