Auto Gear Position Lights go off
Old Mar 19, 2014 | 05:31 AM
immo's Avatar
immo
Hello there, my car is an auto 07 MCS.
Recently i am having some issues.
The lights on the shift boot go off, and when i pull the gear stick to the left, nothing happens.
This is caused by a blown fuse.
The auto wipers fuse with 5A.
We change it, it goes away for a while and it goes off again.
What might be the problem?
Thanks.
Attached Thumbnails Auto Gear Position Lights go off-image-3718053311.jpg   Auto Gear Position Lights go off-image-2579185308.jpg
Old Mar 19, 2014 | 07:51 AM
immo's Avatar
immo
Fuse no is: F17
Old Mar 20, 2014 | 09:25 AM
Slave to Felines's Avatar
Slave to Felines
I have read here that there are electrical bits underneath the cup-holders that can be shorted by water dripping onto them. Perhaps this is related?
Old Jul 21, 2014 | 08:59 AM
immo's Avatar
immo
Here's an update:
The issue went away for a good 3 months and came back this weekend.
What I did to the car (other than usual, was to get the coilovers to a higher setting.)
Electrically nothing new happened.
The issue repeated itself on 3 occasions ( I changed the fuse 3 times)
- Going over a bump
- Cruising on the road ( Auto Lights on Auto Rain Wipers on )
- Going over a bump
Do you guys know where is the TPMS sensor located in 07 MCS? I narrowed down the problem to that sensor, because I tried switching everything else.
It might be a bad cable maybe. I will get the car lowered tomorrow. See what happens.
Old Jul 21, 2014 | 09:01 AM
immo's Avatar
immo
F17 5A 30G X11008 18 0.5 RT/VI Rain/headlight sensor
X11008 9 0.5 SW/RT Transmisson control, Tire pressure control (RDC)
That is the bad fuse.
Old Jul 23, 2014 | 03:29 PM
immo's Avatar
immo
Problem solved.
Apparently a cable going near the transmission has been damaged due to high heat and low suspension, that's why the fuse was getting blown everytime I went over a speedbump or a hole. We changed the cable, changed the fuse and no problem ever since.
Dec 23, 2015 10:36 AM
maestro39
Oct 27, 2015 02:38 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
