Need Help - Confirming EBC Pad Part Numbers
Old Mar 12, 2014 | 12:28 PM
Bigdaddy0128's Avatar
Bigdaddy0128
Hi All,
This weekend I hope to replace the pads and rotors on our '08 Clubman S without JCW.
Can anyone confirm that the front EBC brake pads should be DP21789? I even called Shop EBC and those are the ones they said to get .... but the box says JCW on it.
For the back I have DP21931 and the box says all Coopers 2007+.
I'd rather know now while there is time to order a replacement than Saturday morning with the wheels off and I do a side-by-side comparison.
Hans
Old Mar 12, 2014 | 12:33 PM
Hello,
I can help you,
For your 2008 MINI Clubman S without JCW. ( They are the same JCW pad for Gen 1 MINIs only ( R50 R52 R53 ) ). You have a Gen 2 .
Fronts DP2178
http://www.ecstuning.com/Search/SiteSearch/DP21789/
Rears DP21931
http://www.ecstuning.com/Search/SiteSearch/DP21931/
Old Mar 13, 2014 | 08:31 AM
3lusive's Avatar
3lusive
If your Clubbie has the same brake system as an 08 Hardtop S then ECS Tuning is right - I used DP21789 for the front and DP21931 in the rear on my brakes.
Old Mar 13, 2014 | 10:12 AM
Bigdaddy0128
Thanks for the replies. Installed the pads and new rotors this morning and everything they fit perfectly.
Only panic moment I had was trying to retract the rear brake pistons with a 1st gen caliper tool on 2nd gen car. The little nubs wouldn't stay put. Advance auto parts to the rescue with a loaner set of tools.
Only thing left to do after the victory lunch is slap the wheels back on.
Hans
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
absolutcamper
Aug 24, 2015 12:27 PM
vanhick
Aug 19, 2015 09:03 AM
xraycat
Aug 15, 2015 06:43 AM
