Tachometer display not working - no odometer reading
Old Mar 5, 2014 | 02:41 PM
mochi's Avatar
mochi
The odometer display and temperature display windows just went blank on my 2009 MCS. The turn signals, high beam indicator icons etc above the window where the temperature normally is displayed all work. The icons illuminate normally on startup. Just the 2 display windows are completely dark. Otherwise car runs fine. Any ideas before i schedule a service appointment? Thanks!
Old Mar 5, 2014 | 06:40 PM
booktrout's Avatar
booktrout
My favorite card to play on the guess my electrical problem game is the Dead and/or Dying Battery Card.
I have a 2009 as well, and I'm constantly paranoid of the odd or unusual quirk or sound, wondering if it is time for a new battery.
Keep us posted.
P.S. They always say go to Auto Zone or O'Reilly's and have them check the voltage and amps.
Old Mar 6, 2014 | 04:40 AM
mochi's Avatar
mochi
Well after sitting overnight I started it up and voila, it's back to normal for now. Stopped and started a few times and seems to be OK. I'll keep an eye on it.
Old Mar 6, 2014 | 01:20 PM
booktrout's Avatar
booktrout
Back to normal. That's good news.
Old Jan 10, 2015 | 07:48 PM
DarrenK's Avatar
DarrenK
Sorry to bring an old topic back from the dead but I can't find anything else on this.
mochi, did this ever happen to you again?
The exact same thing has happened to me half a dozen times in the last 10 months ('09 Cooper S). It's happens at random times, first start up in the morning, restarting after a long trip, restarting after a short trip and it's happened in every season (so every temperature).
If I leave the car for an hour or so (or overnight) it's returns to normal. I guess it could be a sign of a weak battery but it shows no weakness even when starting at -30C (nor does it explain the problem happening in Summer or after a long drive).
I've never took it into the shop because I know I'll get a 'can't reproduce the problem' response.
Just thought I'd chime in.
Old Jan 11, 2015 | 09:19 AM
AZdsrt's Avatar
AZdsrt
As mentioned early in this thread, how old is your battery? Odd electrical problems show up on mini's with a marginal battery..
Old Mar 1, 2016 | 11:49 AM
geofox784's Avatar
geofox784
Is anyone else still having this problem or found a solution? This has been happening to me for a few months.
Old Mar 1, 2016 | 03:53 PM
DarrenK's Avatar
DarrenK
My '09 S still did this up until recently when I traded it in. In the two and a half years I owned the car it blanked out about 20 times.
I mentioned it to my dealer once and they said unless it's doing it at the time my car comes in they can't investigate it. They said it MIGHT be my battery but they wanted an hours diagnosis fee to test the battery. I declined. I never, ever had any signs of a weak battery during my ownership.
The only time the tacho never blanked out was during late Spring / Summer / early fall when the weather was warm.
Old Jun 1, 2016 | 09:27 PM
guspi76's Avatar
guspi76
I disassembled the Tach assy and unplugged like 2-3 plugs inside of it. I'm guessing the connectors corrode and do not make a good contact. Affects spedo. After plugging in/out a couple of times, I put it back together and worked just fine. Try this. Good Luck
triple5soul
21
Jul 29, 2016 04:27 AM
stellaherself
Aug 14, 2015 05:28 AM
FrostyFox
Aug 12, 2015 02:33 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
