Downpipe leak and influx boost
Old Mar 4, 2014 | 12:41 PM
micromini234's Avatar
micromini234
During my install I damaged one of my turbo housings screw, there Is a possibility it's leaking right at the mounting point; would this cause boost to slowly be lost?
I will be driving along with the same force on the pedal and the boost slowly decreases not necessarily one by one though. I'm curious as I've never really payed attention to it.
Sent from phone
Old Mar 5, 2014 | 06:27 AM
micromini234
So I'm not getting anything so let me rephrase the question. Should boost remain the Same constant number when your foot is applying the same amount of pressure, not counting for shifts
Old Mar 5, 2014 | 06:46 AM
nine5raptor's Avatar
nine5raptor
No, unless your RPM, resistance, and other factors are identical. Holding steady as RPM drops will cause your boost to drop off as well. Holding a constant acceleration (continuously moving the pedal to adjust for such) will keep the boost relatively constant.
And a leak at the downpipe connection will not cause your boost to drop off by itself. At that point, it has already spun the hotside of the turbo. Is the leak there or somewhere else?
Ian Landesman's Avatar
Ian Landesman
The DP is after the turbo, so I can't see you losing boost from an exhaust leak. Did you touch the exhaust manifold? Maybe you have a boost leak from not retightening a boost tube?
Old Mar 5, 2014 | 06:49 AM
micromini234
It's where the downpipe meets the actual turbo or where the gasket is. One of the nuts stripped and the gasket isn't sealing completely.
Is it possible the turbo isn't getting enough exhaust to keep the boost?
Old Mar 5, 2014 | 07:03 AM
Ian Landesman
No. The turbine is BEFORE this point. It's not possible. You could have an exhaust leak and you are placing more stress on the remaining two bolts...
Old Mar 5, 2014 | 07:24 AM
nine5raptor
Agreed. This will not affect your boost output. It may melt soft (plastic) components in the area though if you are blasting them with 1600F or higher temp exhaust gases due to the leak.
Old Mar 5, 2014 | 07:38 AM
Dr. Spade's Avatar
Dr. Spade
Get the stud out if a nut is stuck on it and use a bolt.
If you strip the inside of the hole, use a bolt and nut on other end.
Old Mar 5, 2014 | 06:01 PM
micromini234
Originally Posted by Dr. Spade
Get the stud out if a nut is stuck on it and use a bolt. If you strip the inside of the hole, use a bolt and nut on other end.
Yeah I tried that I couldn't find a bolt and nut that went all the way through and could support the torque.
I was able to get the bolt about a quarter of the way in with the nut. It's torqued to 30lbs but even then it's not that tight, it was the best I could do
Old Mar 6, 2014 | 06:06 AM
Ian Landesman
I bet ECS can supply you with an OEM bolt.
Old Mar 6, 2014 | 06:09 AM
micromini234
It wasn't the bolt and nut- I got new ones from the dealer, it was the threading inside the turbo part.
Old Mar 6, 2014 | 10:27 AM
Ian Landesman
Ah, ok. I was worried about that when I had to take my DP out. You have the option of retapping.
Old Jan 2, 2015 | 12:11 PM
ncorpuz34's Avatar
ncorpuz34
I apologize for bringing up an old thread, but did you ever find a solution?
I may be in a similar boat with my DP not properly tightened to the turbo housing.
Wouldn't a leak at that point cause a loss in backpressure velocity, thus not opening the wastegate as much as it should?
I have no power when flooring it in third gear at 2K and my gas mileage has gone to sh*t. I suspect either the leak can cause my issue or my fuel pump may be on the way out.
Old Jan 2, 2015 | 12:16 PM
micromini234
Originally Posted by ncorpuz34
I apologize for bringing up an old thread, but did you ever find a solution? I may be in a similar boat with my DP not properly tightened to the turbo housing. Wouldn't a leak at that point cause a loss in backpressure velocity, thus not opening the wastegate as much as it should? I have no power when flooring it in third gear at 2K and my gas mileage has gone to sh*t. I suspect either the leak can cause my issue or my fuel pump may be on the way out.
I don't have a solution. But I ended up not having a leak in the downpipe. A leak in the downpipe would certainly melt anything it's coming into contact with. IE. I forgot to put the O2 sensor back in closed can't remember if I closed the hood but it melted it.
Old Feb 11, 2020 | 10:28 AM
Jeremyj's Avatar
Jeremyj
might try some jb weld if it stripped but then it's a turbo swap.
mizme
Oct 5, 2015 02:10 PM
gzaos
Sep 14, 2015 04:21 AM
mbatech
Sep 10, 2015 03:40 PM
joshuatrost
Sep 5, 2015 02:58 PM
Sep 2, 2015 11:15 AM
