Newbie- rear tires cupping
Old Feb 26, 2014 | 01:59 PM
garlicpapa's Avatar
garlicpapa
Just purchased an 11 Countryman with 26,000 miles. The rear tires are cupping on the inside, and from what I've read thats not uncommon given the the negative camber. My question is for those who have rotated their tires to the front that had cupping. First, did you experience any vibration in the steering wheel? Second, was the noise any less given less negative camber in the front? Thanks
Old Feb 26, 2014 | 02:09 PM
ashchuckton's Avatar
ashchuckton
You need to rotate & balance your tires at regular intervals. Sounds like it is too late for your rear tires. If you put them on the front even after being balanced they will most likely shake the wheel.
W0TM8
Dec 19, 2019 07:50 AM
kazyn
Oct 25, 2019 02:34 PM
Toolman
Jan 20, 2016 06:50 AM
caiken
Aug 27, 2015 06:55 AM
