Drivetrain Catless Downpipe w/ stock exhaust & AP Stage 1 Tune?
Old Feb 21, 2014 | 11:17 PM
Dr. Spade's Avatar
Dr. Spade
Is this combo a good idea?
Or is the DP & exhaust best if all (with stage 2 tune) or nothing?
I currently have a K&N intake & Stage 1 tune. Planning on putting on a Riss racing 2.5" catless DP but rest of exhaust is stock.
Stage 2 tune is for full 3" and I don't plan on changing the exhaust from stock. There's no tune (at least preloaded) that fits.
I did a quick search but haven't found a definite answer. Your input is appreciated.
Old Feb 21, 2014 | 11:30 PM
MarioKart's Avatar
MarioKart
Vendor
I have a DP and stock exhaust with 4" tips and I make great power 250whp and 270wtq. The stock is great, just remove your cat and the second one if your car has one.
Sent from my iPhone Office
Attached Thumbnails Catless Downpipe w/ stock exhaust & AP Stage 1 Tune?-image-441026428.jpg
Old Feb 21, 2014 | 11:54 PM
ra2fanatic's Avatar
ra2fanatic
^You have a GP2 N18, he won't get nowhere near that
Old Feb 22, 2014 | 12:00 AM
MarioKart's Avatar
MarioKart
Vendor
True but my stock exhaust is perfect. I added a resonator where the second Cat was. It's very mellow till you get on it. DP makes power and exhaust is only for looks and sound. The 4" tips help it look more aggressive
Attached Thumbnails Catless Downpipe w/ stock exhaust & AP Stage 1 Tune?-image-2807878142.jpg
Old Feb 22, 2014 | 08:39 AM
nine5raptor's Avatar
nine5raptor
Stage 1 would continue to be appropriate. The AP map will suppress the DP cel. Going to a catless dp will allow for slightly quicker spooling. The power/load/torque will still be dme controlled through wastegate modulation.
Old Feb 22, 2014 | 09:17 AM
Dr. Spade's Avatar
Dr. Spade
Excellent. I just wanted to make sure there wouldn't be any negative effects.
And that's darn good power. I'll take those stock GP2 tips if there still around
Old Feb 22, 2014 | 10:04 AM
MarioKart's Avatar
MarioKart
Vendor
Excellent. I just wanted to make sure there wouldn't be any negative effects. And that's darn good power. I'll take those stock GP2 tips if there still around
The exhaust is stock, but I welded on 4" double walled tips.
Old Mar 18, 2014 | 06:55 PM
Dr. Spade's Avatar
Dr. Spade
So upon realizing the misfire codes were not a result of carbon buildup or HPFP, I changed the tune to stage 2.
It got fewer codes but seemed confused. So the resonator and 2nd cat are now out; replaced by a straight thru resonator and a bit of piping. Rest of exhaust is stock.
CEL stayed off for a longer period this time, but it's back. Got 3 codes.
I figure this may be a result of using the secondary O2 extension...? For those of you with no cats, do you use an O2 extension/defouler with the stage 2 tune? Doesn't the sensor get burnt up since there's no cat?
Old Mar 19, 2014 | 07:55 PM
Dr. Spade's Avatar
Dr. Spade
P2773
P2ac2
P2a75
I have these codes even with stage 2 tune and O2 extender.
About to rage quit back to stock cat.
Old Mar 20, 2014 | 06:27 AM
Grizld700's Avatar
Grizld700
I'd be more inclined to say its the tune. There is too many people out there with catless DP with no problems for me to think its that. And on a similar note, there are too many people the AP tune with random problems here and there for me not to think thats the problem.
My advice, sell the AP and get a real tune from a tuner. Battle, Evolve, JZW and RMW to name a few. You'll get personal service and they can adjust the tune as needed. Trust me, you'll be alot happier you did.
Old Mar 20, 2014 | 07:56 AM
Dr. Spade's Avatar
Dr. Spade
Thanks. I'm gonna give no O2 extender a try (if the sensor will reach; bung is placed lower than stock). If it doesn't work I'll follow your advice.
Old Mar 20, 2014 | 07:45 PM
iceflowdude's Avatar
iceflowdude
I have heard of someone relocating the O2 sensor to after the secondary cat on a 335i, after doing a catless downpipe I believe. Apparently the second cat was enough to keep the light off. Just some food for thought!
Old Mar 21, 2014 | 03:44 AM
killy19's Avatar
killy19
+1 on this I run a cat less dp and have no CEL. I run the JZW tune.
Old Mar 24, 2014 | 10:41 AM
iceflowdude
Anyone tried running a high flow cat while tuned? I want a bit more power but don't want the stinky smell of going catless. I hear the power gains are similar.
Old Mar 24, 2014 | 12:38 PM
6000pounds's Avatar
6000pounds
Sneaky sneaky trying to make your car faster without me knowing. I see you now lol. You got http://www.pawmotorsport.com/ down the street from you. You should go to them or renntech here in lake park. I'll even pick you up if you need to drop your car off over here.
Old Mar 24, 2014 | 01:01 PM
MarioKart's Avatar
MarioKart
Vendor
I barley have a smell, and that's only if I'm going 100% and redlining it. I have no cats and there is no smell if II don't race it. Also, if there is smell, it's only on the outside. Never in the car.
Old Mar 24, 2014 | 07:23 PM
Dr. Spade's Avatar
Dr. Spade
PROBLEM SOLVED! Don't run stage 2 tune with an O2 extender. Car will think it's running lean.
Also don't delete the primary cat on a stage 1 tune with or w/o defouler. It gives missfires and may run lean.
It really doesn't stink much. My Miata with a high flow cat smells worse than this w/o cats. Try having an exhaust shop delete your secondary cat for an easy slight jump in power
Thanks man, I've heard good things about PAW. But I'm doing things on the cheap. Kind of a sleeper stage 2 since most of the exhaust is stock. We still need to run; you do have an intercooler on me.
Old Mar 24, 2014 | 11:49 PM
Ch28Kid's Avatar
Ch28Kid
Basically don't use o2 extender if you have AP?
Old Mar 26, 2014 | 09:38 AM
ALTA_Chris's Avatar
ALTA_Chris
Yes, never run one a O2 extender with the AP, especially on the front O2, it's not needed, and will cause CELs! Running an extender on the front O2 is especially bad.
Old Mar 27, 2014 | 01:45 PM
Dr. Spade's Avatar
Dr. Spade
Correct. It didn't do it's job in any of my previous scenarios.
Teh
Aug 22, 2022 04:37 AM
Colt45Magnus
Aug 13, 2015 11:18 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
