R56 jack stands and missing jack points
Old Feb 19, 2014 | 12:43 PM
djenks76's Avatar
djenks76
So I got everything to change all my brakes and rotors. When I ordered all the stuff, I also made sure that all the jack points were in tact. I started to do the work last night, but I guess with all the snow and ice from the last few weeks, the jack points are now missing. Should I wait for replacement to show up or is it ok to use jack stands without the jack points?
Thanks!
Old Feb 19, 2014 | 12:49 PM
Capt_bj's Avatar
Capt_bj
you could cut some blocks of wood to serve as the jack point pads --- I actually have blocks that fit inside of the jacking blocks and allow the jack saddle to stay away from the plastic block's edges . . .
Old Feb 19, 2014 | 04:29 PM
afadeev's Avatar
afadeev
Thanks!
Put a hockey puck in your jack saddle, and they will provide all the protection and extra grip you need to safely lift the car. I used them even with the plastic jack saddles in place.
It also helps if your jack stands have flat (vs. saddle) tops.
I would order replacement jack points sooner or later regardless.
a
Old Feb 19, 2014 | 04:47 PM
djenks76's Avatar
djenks76
Thanks for the replies. I've ordered the replacement points but will have to do my brakes before they arrive. Unfortunately, the only hockey puck I have is one I caught at a Caps games. I will have to check out the only sporting goods store in my area to see if they carry them.
Old Feb 19, 2014 | 06:54 PM
afadeev's Avatar
afadeev
FWIW, I've used the same hockey puck for 15+ years on BMWs, Mini-vans, and now MINI. They are practically indestructible
If ****'s doesn't have them, the local skating rink will.
I know yours is kinda special, but in all likelihood, you wont be able to tell the difference after using it to hold up your car.
a
molala
Oct 2, 2015 01:53 PM
PelicanParts.com
Sep 9, 2015 01:42 PM
Filmy
Sep 7, 2015 08:27 PM
Suspension Products
Sep 3, 2015 09:41 AM
